I see a trend occurring
:naughty: Perhaps....although I might still enjoy the "classic" finish on my next Spy.....:thinking:
How can one go wrong when perfection can be had in so many ways! :thumbsup:
Guys, what are the lumen ratings on the XM-L?
The board in the XM-L is the same as the one in the Tri-V, so It cane run up to 3000, xp-g runs up to 1400.
OK yeah, you could say that the runtime is reduced. But my real world experience is, as you're carrying and using the light on a daily basis, it spends a small percentage of its time at 3000 mA. So the actual runtime difference may not be so much. Its having the power when you need it but easily being able to dial in a more reasonable level that makes this work well.Good point. Max drive for xpg is only 1.5amps as opposed to 3amps for XML.
Meaning the XML is much brighter when fully driven but runtime is greatly reduced.
To get the 3amps driven level, is IMR battery required?
If a RCR123 is used, what is the maximum drive would it go!?
Dave. Are you planning to incorporate the new Tri-V2 lockout sequence into the Spy007. I think this will be the most used feature in any of your lights given the knob movement is so fluid.
