Yep those are the part numbers that I got. For getting the lens distances right I moved the fresnel lens so that the image is focused then I moved the small lens so the cone fills the fresnel lens, then I repeat those two steps till it's good enough. A glare reducing enclosure would be nice but it would have to be light.
can you tell me the distance between the led die and the back of the first lens?
the same for the second lens would also be good to verify the calculation.
1 difficulty with calculating this setup is the use of the first lens which is quite thick. I will see how close a thin lens approximation comes to the reality. The thing is that this calculation would be correct if you use the principal planes of the first lens to measure/set distances, but that info is not available at the anchor website.
