one is the SkyRC MC3000, but it is a rather expensive charger.
I hacked together a "6 cell battery pack" based on a cheap xtar 6-cell slider charger, and added RC power and balance connectors. Unfortunately what i found is that this tends to exercise the fail-safe error checks in my rc charger.
It seems that In a real rc pack, the batteries start off very similar (probably even same lot) and while they all degraded individually, they do all see exactly the same discharge, storage, etc ... whereas my "faked" 6-cell pack was different enough to (eventually) be caught as an error. For example, i start off by using 'equalize mode' to set the same voltage on all cells, then commence storage (charge or discharge, depending). Invariably one cell would diverge fast enough from the others for the charger to enter an error state.
So, i found a sale on the sky MC3000
Should have done this from the get-go, i suppose, although it was fun to put together the slider unit.
I'm very happy with the MC3000 *except* that the metal tabs seem quite weak compared to the springs. I have already bent a couple and had to bend them back ... i hope it holds up.
