Norm, I wear glasses everywhere, so maybe mine is just wimpy. I'm running it off of 4x Imedion AAs...
Anyway, the Night Com just showed up today, adding my thoughts to subwoofer's review...
1) other than the tapered body behind the head, the Night Com is almost exactly the same size and shape as my Surefire 6P (which is slightly longer than a standard 6P due to the Malkoff MD2 tailcap.) In fact if I take off the lanyard ring, and/or am careful to insert it with the protrusion in one of the "corners" of the holster, it'll fit in the Surefire V27 holster (mine is old and a little stretched out at the top, which is perfect for the Night Com.)
2) I have no trouble changing the mode dial with my thumb, but I wish it had more distinct detents.
3) The switch is very similar to but slightly different from the McClicky in my Surefire. It has a little longer travel and is slightly stiffer. I'm not sure which I prefer, honestly. Both are nice.
4) Tailcap is slightly shrouded unlike stock SF Z41. Does not tailstand however.
5) Light output on low and high modes seems to bracket the output of my Malkoff M61L 219, with high mode probably being closer to the Malkoff. Purely subjective assessment as the color temp of the Night Com is much higher, although not really into the "Angry Purple" territory. Spot and spill areas are very similar, with the Streamlight being ever so slightly tighter. Other than the artifacts noted by subwoofer due to the six UV LEDs it is actually rather good, with a similar slightly gradual transition as it is also an orange peel type reflector.
6) the UV makes items fluoresce much more than my tube light - the laundry room is the darkest room in the house during the day and the first thing that I noticed was some detergent spills on the floor and some drywall debris on top of the water heater which only dimly glowed with the tube. It also pops the strip on a $20 bill much more brightly than the tube, and makes the tritium tubes on my wristwatch go ape****
7) Knurling is not as aggressive/grippy as Surefire. Just a comment, which is better is personal preference.
To summarize, I think that the combination of this light and a Surefire holster might become part of my "working on cars" kit which was the original intent. If I had any nits to pick with the light, it would be:
1) inability to use RCR123As (had I known I was going to buy this light though, I would have bought 17670s or 16650s for both this and my 6P.)
2) needs better detents on mode dial
3) needs deeper shrouding on tailcap switch for tailstanding ability
4) why no holster offered by Streamlight? (but the fact that the Surefire one works makes this really a non-issue.)
5) as is true of every light that isn't a Nichia 219, tint and CRI is inferior to a Nichia 219
In short... I like it, and am happy with the purchase.
If I have anything to add after using it for a while, I'll check back in.
