Thinking that Sunways are nice, elegant and feminine, I was thinking of getting my missus a Sunway V10R Ti:
http://www.candlepowerforums.com/vb...tbeam-TC-R2-and-Sunwayman-Ti-V10R-PHOTO-HEAVY!
The review here says it's very good, and I agree there's not much difference between the two titanium flashlights Jetbeam TC-R2 and Sunway V10R Ti.
The TC-R2 bigger, more powerful, more masculine, most importantly, the TC-R2 magnetic ring had a "Standby" & strobe, and a proper belt clip secured by two screws!
JB also uses a brighter and more polished Ti surface which my missus liked.
The V10R Ti is generally more feminine, but my missus wanted the TC-R2, so I got her that.
The TC-R2 is just a Ti version of RRT-0 really, but it does have the best belt clip, and a more powerful 310 lumen Cre XP-G S2 emitter.
Supranatural, your RRT-1 with midsize 48mm head, the M1xm & RRT-3 with 63mm heads all have big reflectors and throw superbly.
I wish Selfbuilt would do more reviews on Jetbeams, esp the RRT-0, 1 and 3; I know there are other Jetbeam reviews on CPF, but Selfbuilt's are the best - lately, he even gives you the maximum distance where the flashlight is only delivering 0.25 lumens, so you know how far the maximum throw is.
Besdides, there is nothing wrong with several different reviews with several different opinions.
On this topic of "switch gear".
I can appreciate why only the "big" flashlights use buttons - which are the most comfortable, ergonomic to use.
For a small flashlight, such waterproof rubber buttons are bulky and being rubber, lack longevity.
For compact flashlights with only one or two CR123's, I can understand the love for magnetic rings and tail end switches, plus head and tail cap twisting etc.
Supranatural, you are right about head and tail cap twisting - it often requires two-handed operation - so it's a no no.
I can actually think of another solution for manufacturers - how about a spring-loaded, thin, flat, metal slide? For a compact flashlight, this is more compact than a button.
It could be a one-way slide backwards only, or a two-way slide backwards and forwards.
One-way: sliding backwards will turn on and off, while holding the slide will jump between low, medium and high, back down to medium and low etc, while two quick slides gives you the strobe!
Two-way slide: sliding backwards turns on, and changes between low, medium and high etc, while sliding forwards turns off! For the strobe, we could either hold the slide backwards, or do two quick slides.
If manufacturers want the switchgear to be very compact, then the magnetic ring combined with the tail end switch is still the most compact!
I have a RRT-2, it has standby - that's great - something the Sunways should have.
However, on the RRT2, after standby, comes strobe, then low, medium, high.
Like Selfbuilt said on
http://www.candlepowerforums.com/vb...aptor-(R2)-Review-RUNTIMES-BEAMSHOTS-and-more!, that's quite silly to have strobe there - I don't know if Supranatural agrees on his RRT-1?
Strobe should either be to the left, then standby, then low, medium, and hi like the RRT-0's and TC-R2's.
Or strobe should be to the far right after high, like the RRT-3 and most of the Sunways!
Btw, the standby's on all the Jetbeams should be genuine "off", not just standby, since the tail end switch is uncomfortable to hold overhand/cigar and head heavy, plus the body of the RRT-2 is a little short to hold overhand, but if the magnetic ring is moved forwards, then this will interfere with the head and reflector.
The only disadvantage of the 5 position magnetic ring, is that you cannot "combine" that with Sunways superb T20C tactical tail end switch, which moves from on/off, holds for low medium high, and double clicks for strobe.
We can't combine the five position ring with the T20C tactical tail end switch because the 5 position ring actually "locks in" the mode already!
However, if you think about it, you can combine the T20C's tactical multi-function tail end click with the compact magnetic ring, if that magnetic ring is NOT of the 5 or multi-position type.
How about using a one or two position spring loaded compact ring?
The spring loaded ring can be twisted to the left only, or to both left and right.
Left twist can switch on and between brightnesses.
While a right twist switches unit off etc.
Hold the twist down, or double twist the spring loaded ring, and it turns to strobe!
In the end, the current RRT-0 and TC-R2 design with magnetic ring: strobe, standby, lo, med, hi - modified to a real off [not just standby], and combined with the tail end clicky is very very good.
Also, an innovative one-way left, or two-way left and right spring-loaded compact ring with a tactical multi-function design like one twist on, lo, med, hi, right twist off, hold down or double twist left strobe, combined with the T20C design tactical multi-function tail end clicky here, would also be good.
A spring loaded thin metal sliding switch could be an alternative to ring, but not as compact as ring...
It helps if a flashlight is easy and comfortable to hold, and switch between modes...
