I'm sure that'll be heat. Batteries work better as they heat up. The ones closer to the bezel will heat up faster.
We know that CR123A batteries are strong and robust and tolerant.
Being responsible with batteries means not disadvantaging them right from the start.
If the behaviour you noticed using the ZTS was usually and normal use was a problem we'd all be in a world of hurt. Since we're not I think that responsible normal battery practices coupled with responsible flashlight practices are sufficient to minimise battery-related incidents to the extent they are a non-issue.
Mix batteries and act carelessly not disabling your flashlight and you dramatically increase the risks. Even so the chances of being bitten by your sloppy and irresponsibly behaviour is low. Which isn't the constructive reinforcement of positive behaviour that will make the world a safer place.
Al
Al, I want to play devil's advocate for a minute. I just looked at my L2, M4, M6 boxes and enclosed papers. I keep everything. There is absolutely nothing in these about using fresh batteries, not mixing with used, locking out the tailcap, or removing batteries when not using. Nor is there anything specific about the dangers of the 123A cell.
There is some minor battery instructions in the most recent SF E2D I got, but not what I would consider adequate warnings.
I do not think you can expect the average consumer to know the dangers on primary Lithium cells unless they are clearly warned and don't read/follow those enclosed instructions. You certainly cannot say they are being irresponsible. Well I take that back. You can say it, but it is not accurate.
In fact, if any fire, damage, bodily injury, or loss of life occurred from older SF lights & batteries, I guarantee that a lawyer would eat SF alive. Regarding product safety litigation, the company would be held irresponsible and liable if they did not give adequate warnings to the consumer for dangers they know about, and which in my lights SF did not.
In addition, several boxes I bought this year with expiration dates of 5/2018 also say absolutely nothing about safe use of the cells. There are warnings on observing proper storing, but nothing about safe use, not mixing old with new. I guarantee that guidelines which we know as members of this forum is not common knowledge.
I brought my poor understanding of Alkaline, NiMH, NiCad batteries to Lithium primary and secondary cells when I first joined this forum. I would always just replace the weak battery when tested on one of those cheap hand held battery testers, and had no reason to think it was any different with Lithium batteries.
In this specific (and other) example on AR15 forums, it is not the responsibility of the consumer to later somehow find out that his light should be only used with a lockout tailcap, and follow specific battery use guidelines. Rather, the responsibility rests with Surefire to issue notices to consumers they know bought certain lights, distributors, retailers, and place product safety announcements in public magazines/newspapers to protect the public.
