jon_slider
- Joined
- Mar 31, 2015
- Messages
- 5,159
The batteries that Surefire sent with the Fury Intellibeams did and do work. They just don't perform as long or reliably as the Orbtronic 3500 mAh High Drain with button top. This picture helps explain part of the problem.
Hope this helps.
great info, the picture clearly shows that the USB battery is much longer.
My Surefire Fury Intellibeam ...doesn't work with the Surefire mini USB Rechargeable 18650s
when a battery is too long, the body tube cant close far enough to reach the contact ring in the head.
now that you know the USB battery is too long, and have learned that the light requires a shorter Button Top battery, youre on the way to choosing a battery that works properly in your light.
I can understand your frustration with a battery that does not work in your light. Hopefully Surefire will refund your USB battery purchases..
The problem is not the light, it just needs a shorter, non USB, and button top, battery. Suggest you buy the Orbtronic that Raymond33 recommends.
Do you already own a separate battery charger, or do you need suggestions for a charger as well?
Once you get the proper batteries and charger, I hope you will enjoy your light ;-)
