billcushman
This is an interesting discussion about the Tesla Battery.
https://www.youtube.com/watch?v=VbVpPSa6glA
...I don't think that other battery makers are going to copy this size if they don't get a contract making batteries for them as larger cells will only make laptop and drill battery packs larger as they are built around certain voltages and eliminating batteries to make a taller wider but not necessarily longer pack isn't going to be worth it. Looking at all my 18650 based devices... flashlights and power banks and such I don't see a larger diameter more comfortable a fit.
Why are they going for cylindrical cells, would hexagonal cells pack more in the same space, or do they need a slight gap for cooling?
John.
Sounds a bit like a desperate plan by someone to "improve" the bottom line. If their manufacturing equipment that makes batteries is limited to this new size of battery without major work on it then I guess I can see why they would do this but if they have to make all new equipment to accommodate the larger cell size then why not go to 22800 or even larger? The only savings I can see is they can use less cells to get the same amount of power but the less cells may not take up any less size perhaps even more size when they are grouped together as the holes between cells I believe will be larger and the cells are taller too. I don't think that other battery makers are going to copy this size if they don't get a contract making batteries for them as larger cells will only make laptop and drill battery packs larger as they are built around certain voltages and eliminating batteries to make a taller wider but not necessarily longer pack isn't going to be worth it. Looking at all my 18650 based devices... flashlights and power banks and such I don't see a larger diameter more comfortable a fit.
If they are not 18650 anymore, what are they?
Like somebody said above, power tools are the new laptops for cylindrical cells, IMO.
It used to be draws drills, saws and lights that used battery packs, but now we have blowers, weed whackers, hedgers and even lawn mowers.
None of the tree-hugger hippies want gas any longer and 100 yard extension cords are too much work for the fatties, to roll up.
Chris
I replaced my 5 year old laptop with a new Dell XPS13 9350 and it is 2.5 lbs and 10mm thick with battery life of eight hours. An 18650 battery would not fit.The dollars are not in removable batteries any more.
To be successful these days, laptops have to be at least somewhat thin.
Take a perusal of Lenovo or Dell's website. You are hard pressed to find removable batteries any more or anything powered with 18650. They are just too thick.
Pretty much all lithium polymer. It's the same chemistry, just different physical construction.
