RI Chevy
...........lovecpf..........:goodjob:
updates on this?
Subscribed.
So with this new Viking pro is there any talk of the predators being discontinued anytime? I want to pick one up but I can't choose...
Subscribed.
Couple of clarifications plus a couple of questionsNo, the Viking Pro replaces the Predator X, not the Predator. The Viking Pro uses XM-L2 LEDs and the Predator with its tighter beam uses a smaller emitter the XP-G2.
The choice you need to make is over the tighter or wider beam.
- clarification, the XM-L2 has a wider hotspot than the XP-G2 (10-degrees vs 5-degrees), but the spillbeam angle is still the same 40-degrees for both, so when you decide between tighter or wider beams, it's just the hotspot and intensity, as the the XM-L2's beam is not wider than the XP-G2's.
Questions:
- Is the Viking Pro simply a renaming of the Predator X Pro? At one point in time IIRC, the Predator Pro and the Viking had different UI's (with the Predator Pros having a more customizable UI). Do they both have the same UI but just different names now to differentiate the models by emitter/reflector? Their website claims that the Predator Pro UI has 5 modes vs the Viking Pro's 4 modes, but the website could need updating or have a typo (such as the Viking Pro Warm XM-L2's 620 lumens for 20h, where they obviously made a mistake with an extra 0. It should have read 62 lumens for 20h).
- Does this mean that the Predator Pros are now only going to be the XP-G2 models (OR at least till a another emitter comes out)?
Max
