Ok guys,
if I would waited for you guys...I'd probably never get myself a new, Terralux TLE-300MR-EX dropin. :twothumbs
First observations: Beam shape remains the same: It's a bit funky on a white wall, but outside/a bit longer distances you won't notice that. I was pleasantly suprised by the tint: It's quite warmer than the tint of TLE-300MR. But still on a "cool side", pretty much the same as my Nitecore Extreme's. Probably LED's are the same: CREE R2's.
It's a bit brighter than the old one, but there isn't a big difference.
How to change modes: It has no memory so you have to cycle through three brightness setting. You can use momentary (press for high, depress, press again for medium, depress, and press for low, deprees. If you press again you're on high again.) You can also click for constant on(high)turn it of, then click again(medium)... Probably the best way to get the desired level is combination of momentary and constant: Let's say you want to get the low mode: press two times, third time click all the way down and you're in low mode (
note: i assumed that first press was for high)
**About PWM sound: You can hear a light squeeeeek when you're in medium, and even louder when in low. But i could hear it only when flashlight was still dismantled. When everything was back together i couldn't hear anything (i still can't actually:laughing
Beamshots: Be aware, that i used point and shoot camera with automatic settings only. These beamshots are taken just for relative comparison!!!
I compared Magcharger with TLE-300MR-EX, Surefire LX2 and Nitecore Extreme R2.
First from left is Terralux, second LX2, right is Extreme R2
All flashlights on highest mode:
Terralux on medium, other on high:
All three low (lowest on Extreme R2)
Terralux high, other low (lowest on Extreme R2)
Beam-shape of TLE-300MR-EX
Now two more pictures of flashlights appearance:
This is all for now, hope i helped you guys a bit. Btw, i have UCL lens on my Magcharger, and i used original lens "sealing" and o-ring that comes with drop-in. There's no rattle or anything.
For outdoor beamshots please go to:
https://www.candlepowerforums.com/threads/245852
but unfortunately there are pictures of my old TLE-300MR. However, those pictures are made with locked camera setting, to see the real performance of my three flashlights. New 300MR-EX should be a little bit brighter and with warmer tint.
I apologize for language and grammar mistakes.
