Re: Santa brought me an EagleTac G25C2!!
so i'm looking at the G25C2 manual online and if i'm reading correctly: you can customize the 3rd or 4th levels to turn on at either strobe or high-flash or SOS or beacon or low-flash individually?
like i could make the 3rd level to always be low flash? and customize the 4th to be strobe?
kinda like a 4Sevens tactical?
There are a number of options that are available to you to choose between, but if I understand your question correctly, no, the light is not fully programmable in the same way that a Jetbeam light with the IBS UI would (I'm not familiar with the 4Sevens Tactical series). You can't set the light to your own chosen power output, or assign different modes to the light's four level positions.
In many respects, you could consider the G25C2 as being more like a light with a four position control ring, with those positions responding to four preset levels, rather than your normal tactical loosen/tighten UI. Generally, with the common tactical UI, you would tighten for turbo and loosen for general setting (Fenix TK11 for instance), or tighten for high, and loosen for a user programmable mode (Jetbeam IIIM, Nitecore Extreme, etc.) While you are just tightening and loosening the head with the G25C2, depending how far you loosen the head, you can access four different levels rather than just two.
Probably easiest to state what you can do, rather than try and explain what you cant: -
1. Switch between Tactical mode and Regular mode - Tactical mode gives you 100% power, 10% power, and two strobe settings. The strobe settings are preset and non-adjustable. Regular mode gives you power settings of 100%, 35%, 6% and 0.3%.
2. You have a power management setting by default that drops the high setting from 100% to 80% after 200 seconds. This power saving feature can be left on, or switched off.
3. You can set the light so that a double click (or double push) of the tail switch activates the default strobe. By default, this option is switched off. Again, the strobe type is preset and non-adjustable.
4. Not so much an option that you can adjust, as a mode that you can access at any time. There are a number of flashing modes that you can access from high mode by quickly loosening and tightening the head. You can step through the different flashing modes by loosening and tightening the head again. You cycle through the following modes: -
strobe>high flash>SOS>beacon>low flash
5. Again not a programming option, and the parts are an optional extra, but it offers some more versatility - the light functions with a minimum of 2.7 volts, and up to 12.6 volts. With the addition of optional extenders the light can use one, two or three 18650s; one 16340 with a spacer (though I wouldn't bother with that option); two or three 16340s; two, three of four CR123As.
So, you don't have a fully customisable, programmable light, but you do have a number of options you can adjust to make the light better able to meet your needs or preferences.
