Tachead
There are others who put the temp sensor on the mcpcb. You can even get "hobbyist" parts like that now - see led4power.com. None of that changes the fact that you're right though. Zebra does thermal control right, as good as any and much better than most. And as for making it smoother, I think that's a physics limitation, because over the past few years the lights have gotten both stronger (hotter) and smaller. You can't cheat the laws of physics.
Although those boards you linked have a temp lead footprint they are not the same thing. They use a wire to feed temperature from the emitter MCPCB to a separate driver board(usually separated by a bulkhead in the body of the light). ZL uses a single MCPCB for all components. The temp sensor, emitter, and driver are all one piece on the same board. As far as I know, ZL is the only flashlight company doing this. I am guessing this is part of the reason why ZL's thermal regulation is so much smoother and more accurate when compared to other high power lights like the Emisar D4.
