The Vesuvius will use a reflector that I have to modify. Do to the time frame
of this build I only have 17 in stock and will have to order more today. All of
them will go to RMSK as soon as I get them built. I also have to modify heat
sinks and stock heads so everything will fit together.
We were able to get some IMR brand 10440 batteries that work very well and
one of them holds constant output at 1.9 Amps. Yes, it is a AAA battery size
flashlight. I need to do testing with other brand 10440s to see how they hold
up under the strain.
An IMR 10440 LiMn High Drain 350mAh 3.7v Rechargeable Battery is perfect
for powering your Vesuvius ultra output flashlight. The Vesuvius is designed
to use LiMn high drain batteries for optimum performance. Lithium Manganese
(LiMn) high drain batteries are commonly used for power tools, medical
instruments, as well as hybrid and electric vehicles. High drain batteries are
perfectly suited for use in high performance electronic systems. These powerful
modern batteries deliver outstanding performance which makes them the best
choice to maintain constant maximum light output in the Vesuvius flashlight.
Standard 10440 LiCo batteries show a steady drop in output at maximum.
Standard 10440 batteries work fine with the Vesuvius but for that WOW factor
we recommend the IMR brand batteries.
There will be a heat issue with such a small, (read tiny), light with that amount
of power output, but that is why there is the QTC for adjustable output right
down to almost nothing. Quality of the battery is the most important factor with
this light. Not every battery will be able to give an output of up to 650 Lumens.
DWF was over and he had one that delivered 2.3 Amps to the LED, but that is
not normal. Most freshly charged units that I have start out at 1.6 Amps. The
batteries that I have are over a year old and have been charged more than a few
times. A battery that has been over discharged will not perform well with this light.
Proper use of this light is a must. This light is not for the uninformed and definitely
not for children. Do not turn on at full power and leave unattended, the heat buildup
very rapidly can cause damage to the battery and burns to skin.
At up to 600 OTF Lumens in a light that is only slightly larger in diameter than an Eiger,
that is why we said WOW when we first lit it off. No one that you show it to is
going to believe that that much light can come out of something that small. But with
the QTC it is also practical.
The first delivery to RMSK will be Key Ring HA Aluminum. Later we will make some in
Brass and finally in SS. All will be Key Ring styles only. We also have some 2 x AAA
bodies, however use only Standard Alkaline or Lithium 1.5 and 1.6 volt batteries in
the 2 x AAA bodies. The output with 2 x AAA batteries is about 160 Lumens and a
run time of about three hours. A single Standard battery will not power this light.
This is a flashlight for hard core flashlight user only!
Curt
