Hi Curt,
Congratulations and sounds like a great little light.
For the 2xAAA body's, users wanting a high output will be better of with only the Lithium primaries.
Using 2 x duracell AAA may not be able to provide more than 100-150 lumens to the XM-L (assuming a T6 Bin),
because the voltage sag that occurs above 400mA draw per cell, will probably be under the Vf required to power the XM-L.
The Lithium primaries should be good for a much higher draw but probably max out around 1A because the VF increases with power to the XM-L.
tgwnn
Thank you. We had all the parts on the shelf, we just needed to make some
minor adjustments. We had been thinking of using the XML as a an update to
the Rainier that uses the P7 in a direct drive mode, but the LED voltage drop is
too low for that application. We may use a Buck/Boost circuit for that app.
The IMR10440 would automatically limit current to the LED. I measured 430 mA
using two Alkaline batteries to the XML, two Lithium primary batteries may give a
little more, but I doubt that they would get close to 1 Amp. We'll see.
Curt
