I find another thing very interesting about the graph taken by TIN vs the measurements I have made on my lights, specifically the two models that we share, Manker E01 and Thrunite Ti3. The graph shows the light output of the Manker a bit lower with a longer run time. I have measured the current being demanded from a power source at various voltages and I find the two lights are nearly identical at the low level (not firefly), at least to the point I have characterize. I have a couple more data points to gather on the Ti3.
I will start a run with the Manker tonight and see if I can get 10 hours out of the same freshly charged eneloop that I used for the Ti3 run on low above.
Meanwhile, I also find it interesting the Manker and Thrunite share the same firefly current demand characteristics. While the Thrunite draws about 2x the current on firefly, they both demand less current as the voltage drops. This is in contrast to what one would think of normally as constant current regulation. IF the current to the emitter is constant, then the power drawn from the battery should be constant. I find that to hold very closely when measuring lights in modes up to 0.1A or so. But in high modes, where currents approach and exceed 1A, I generally find that the power into the light increases as the battery voltage decreases. I think my test setup contributes to this measurement phenomenon, as I am simply holding short wires from a regulated power supply to the drive board, and I suspect I don't make good enough contact at the higher current levels to get good measurements. I definitely observe the measurement fluctuate and often pick a current value as the display of my power source fluctuates.
Anyway, I will report back tomorrow the results of the Manker E01 runtime at constant output. My comparison sources is the Ti3, while the tint of the light color is very different, the intensity is very close.
Update: measured battery in Manker at 9:30, 1.16V. at 10 hours the battery measured 1.03V with the voltage rising. Slightly less current in the Manker, slightly more voltage at 10 hours. Physics is a beautiful thing.
