Codeman
- Joined
- Nov 26, 2004
- Messages
- 2,690
Don, any idea of runtimes w 2 x L91's on the Haiku in comparison w 1 x 123?
XP-G ran 1.5 hrs on a pair of Eneloops, with 15 more minutes on medium. I haven't tried primary cells.
Whoops - 1.5 hrs on high, then 15 min more on medium.
Since Eneloops don't have low-voltage cutoff circuits, when the batteries can't sustain the necessary wattage, does the light shut off, drop down a level, or drop out of regulation without changing levels?
You ran your Haiku XP-G on high for 1.5 hours with the 2xAA tail pack I was just curious about how it handled the heat did you run it constant or at timed intervals and let it cool down. How long do you think it would run on low with that set up.
According to my bench supply testing the LE remains in regulation down to about 2V, so the difference in light output should be minimal, if any.would you say the output was reduced from 1 x 123?
Can someone please measure the OAL of the pack + Haiku head?
Thanks!
Mine is 6 5/16'' overall.Can someone please measure the OAL of the pack + Haiku head?
Thanks!
Don lists the Pack length in the OP, then just measure your Haiku head.
Either way, its a tall cup o tea that I can't wait to buy!!
