fyrstormer
Banned
I should've known I'd get a geeky, technical answer from a dude who's crazy enough to collect flashlights. Good grief.
I got it, I got it...mayhaps you need to turn up the gain on the old sarcasm detector?Allow me to simplify it for you.
Ahem...
WORKS BETTER.
...sarcasm detector...
Ahh. So there's never a point at which you could get momentary low or momentary high, depending on how deep you depress the button.
If I take your analogy rightly, then you can ONLY momentary or latch, to one power level (low or high), at any one position of the head? Then the U2 analogy makes sense =)
Basically it's kind of like having two different single-stage forward clicky lights, in one? A low-momentary, low-latch, or a high-momentary, high-latch?
Thanks Max!
Yes. There is no software in the PD lights, only hardware. With a PD head and a Clicky Pak, it's basically a twisty with a lockout tailswitch.So do these still work the same as a twisty if you click the light on and then twist on - twist off? Same one handed operation possible?
