scout24
That, sir, is a pretty picture...
There is something about the raw look of the Ti Mule head, emitter and PCB and wires exposed, that is very industrial yet exceptionally attractive looking. When it comes to the "business end", it is one of my favorite lights to gaze upon. Very nice pics buddy. :thumbsup:
Thanks for the reference Dan and also for bumping up this thread! I've been following the renewed interest in Don's CRI models on the forum and it's great to see. These really are the most amazing lights in terms of looks, build, function and utility.
I'll leave the excellent beamshots to Dan, he's so much better at it but I do have a new Mule shot to share Taken just before the Autumn and the shedding of the Maples beautifull colour leaves.
I have three quick questions about the Mule:
1. What Kind of lumens should I expect out of the high CRI Mule? And for the XML Mule (while we're at it)?
2. Could I simply buy the Mule head and use it on the 1x123 Haiku body?
3. Am I on point that the only Mule purchase options right now are the XML and CRI?
Many thanks!
Many thanks!
Man - what you do with a camera is awesome. Beautiful, awesome photo. The colors are amazing. I would love to see that taken with large format film!!
I had the same "problem" when I got my lights, but after a few times of using it you will understand the feel, timing and sequence to click. Your timing when clicking has got to be accurate, fast enough but not too fast. You do not need to click hard to change the output but you need to make sure the switch is fully disengaged before clicking again. Do note also that when you are using CR123 primary batteries, changing output from high is nearly impossible when the battery is weak.after tracing again n again for five days, I got mine finally. awesome n love this!
one question about the clicky. I can put the light on and off with clicky feelings, but to change the brightness, have to click a bit more stronger and sometimes it dosen't work even the "clicky touch". I mean, to change the brightness, I have to press a bit deeper or further in or stronger than to put on and off. is this usual for the clicky switch?
pjandyho, Thanx for your tip. Now I know that I have to get familiar with this switch. also now I'm aware that I get a sign of a weak primaly batteries!You do not need to click hard to change the output but you need to make sure the switch is fully disengaged before clicking again. Do note also that when you are using CR123 primary batteries, changing output from high is nearly impossible when the battery is weak.
Welcome. Hope you enjoy your new light. Once you get used to the switching sequence you will really appreciate the beauty and functionality of this light.pjandyho, Thanx for your tip. Now I know that I have to get familiar with this switch. also now I'm aware that I get a sign of a weak primaly batteries!
