Stingray,
Have you gotten the pack yet?
js, no, it hasn't arrived yet. Seems like it should have been here by now, how was it packaged? Just wondering if it would fit in my mailbox.
Stingray,
I was in on the same deal. $100? if I remember. I'm a bit disappointed in my TL. It was nice and bright but didn't last very long. Now it's a paperweight.My Tigerlight has lost it's bright white beam the last couple of years. <snip> It's from one of those Tigerlight special sales that TW had here back then when they weren't supposed to. Something about old battery packs bought for a deep discount with the agreement not to resell here. Anyway, I ended up buying one unknowingly, the price was good, but the light fizzled out really quickly, wasn't worth it.
<snip> Looks like $150 for a new lamp, battery and smart charger at their website, more than I paid for the light back then. Any other options? Maybe just a custom battery pack that works with my current lamp and charger.
It's going via First Class mail in a padded envelope. No worries yet. It'll probably get there in the next two or three days.
Stingray, maybe it was another deal? I bought a FBOP verison. I still remain a Dissatisfied Tigerlight customer.
I had no way of knowing that. I bought it in good faith and now I have a "Doorstop" with Tigerlight as the product name.It wasn't Tigerlight's fault, it was Dan at Tactical Warehouse. He bought some old inventory with outdated and/or defective components at a huge discount with the explicit agreement not to resell it on the retail market and then he dumped it on us with one of his "big sales".
If tigerlight had outdated/defective lights, why did they sell them to anyone? They should of been scraped as soon as they knew about a problem.
Whatever went on between a Manufacture and a reseller, I'm the one who got screwed.
I just picked up a couple TL's with dead packs. I have a pile of Eneloops laying around and thought I'd give it a shot at making my own pack. I read JS's thread documenting how he built the KAN packs and got my solder station out. I used solder braid for the interconnects, and for the end to end connections I also used the braid and just folded it over before taping the cells in each stick of two. I practiced with a bunch of dead AA's I have in my recycle pile before breaking out the Eneloops. I lifted and re-used the polyfuse and 9v connector from the stock pack and integrated them into the new.
45 minutes later the bezel goes on and I test the light, WOW.
It goes on the fast charger.
60 minutes later it's done and I start a run test. Man do the Eneloops hold under load. I measured the Lamp pulling right at 2.0A after 10 minutes runtime. It was brighter and much whiter than my other TL's with stock lamps and packs, and while not brighter it made my 35x equipped light look yellow. It ran for about an hour before sharply kneeing over and dropping from 7V to 5V in about 20 seconds, I guess the cells are matched well.
I'm very impressed with the Eneloops in the TL.
I was also eyeing up this OC version I have. Hmm, 8 AA cells fit in the barrel, and 4 more would fit in the OC compartment, 6S2P with a couple jumpers through the bulkhead and switch core, and the dummy cap on the tail. Double runtime, and it would still run all the stock lamps and the new LED module. I'm surprised that I have not seen this possibility considered before.
A double battery mod and a multilevel (or gulp, even triple) P7 in the front end could just be the ultimate tigerlight if you are willing to sacrafice the OC, no offense to anything JS has previously built.
~Dougk
EDIT: 4xAA's leave a bit of room side by side so for crapps and grinns I just now tried to see if 5 AA's would fit in the barrel. they do! But they barely even wiggle. you'd have to assemble the pack around the lamp wires and connect it right to the switch. Hmm, I wonder. 12V tigerlight all series, or 6v @5s2p (or 3p using the OC storage area) would drive some LED modules nicely.
they are the standard 2Ah Eneloops.Thanks for sharing. What's your eneloops capacity?
My TL still waiting for the slowly fading 8AA plus LVR solution. I think I have better chance waiting for AW's D size Li-ion....hopefully next spring. I will be using two 18650 in the near future when I get a chance.
Six, same quantity as the stock pack, but it is a bit longer and narrower because they are AA and not 3/4A or whatever the regular cells are. which means it's a little tighter fit to get the lamp in, but not enough that the pins get bent or anything. I made up some of the length by placing the 9V connector on the side instead of the end of the pack, since with the slimmer cells there's room for it next to the pack. I'd offer to build you one, but I don't have any shrink wrap or kapton tape, so they are sort of electrical tape wrapped and quite DIY looking. None of that polish really matters to me once it is sealed up in the light, as long as it is safe from shocks and shorting. I've made two packs so far, at about 45 minutes each to do it isn't hateful, but not what I'd call production line. I figure for $15 in Eneloops and materials + my time I've got a pack to equal the new premium pack with the advantage of Low Self Discharge.Kremer. How many Eneloops did you use on your pack? Are you using the stock LA?
I have a dead TL that I would like to use again.
The 2xD stick will fit? Two 18650's leave tons of room to spare, even with a PCB added, it almost seems a waste of the space, but is the same capacity or better than the factory pack.
