Flat-top cells work good? Or button needed?
Flat tops are fine
Hmmm. This is nice, but compared to the dedomed MM15vn?
Wow, even more than the dedomed mm15vn?
I will take C please u3 dome on with thermal pad and v54 engraving:twothumbs
C. $250 XML2 U3 Dome On
+ $15 Thermal Pad Cooling
+ $5 for "V54" hand engraved on the bottom of the tail cap.
+ $18 if you are outside of USA
Cheers vinh
it can't be 2.8A total so yes it's 2.8A per LED.
All options require high drian for max performance although any cells would work fine. This light is much smaller than your stock Tk75 with performance that i would say almost identical.
Almost identical performance as stock TK75? This light throws 690 meters?!! You must be only talking about lumen output!
Not so fast there. This light dedomed throws very well. If the ld50vn does 45kcd then this must do around 100kcd according to the beamshots right in the tk75 throw range
Just compared the coming Fenix LD75 against the TM06. Although the LD75 has a bigger head, overall the dimensions are equal.:laughing:
tbh its a tough call as the de-dome appeals too,the u3 de-dome would have the perfect choice for me but too many issues with the batch of u3 leds(greens). Otherwise i would have 100% gone that way.
I just love small lights and walls of light,just so useful ,so the u3 was next although the PDTn is a good choice too. I just prefer the cooler end of tints in general or 5500k on.........
Thanks Vinh!
Maybe Justin can test it. We will have to wait and see!
No fooling! I was being sarcastic.but im not Vinh lol
That isn't saying much. Even de-domed, the MM15vn does less than 30kcd. After all, it was designed completely and totally for flood. This light is more of a hybrid. Lots of spill, but a fairly intense hotspot too.
