MAD777
Re: TX25C2vn - Pocket Throw King
Ouch! I just bruised my chin as my jaw dropped onto my desk!
I am curious, since you have the ability to use your own side-clicky driver in this light (which means you can use any emitter available given the sinkpad would fit), what are the chances of the TX25C2vn having a MT-G2 option? Or even one of the Luminus LED emitters? Battery configuration isn't much of an issue since Eagletac offers up extension tubes for this light and many other of their line, plus we could always use two 18350's in the single 18650 tube if needed (albeit at reduced mAh runtime).
MT-G2 in a pocketable size like the TX25C2 (using two 18350's) would be amazing! The deep reflector would at least give it a little bit of throw, probably comparable hotspot size to a XL-L2 in a smaller sized light but with ~3000 lumens and a phenomenal tint!
Is this a kit with the diffuser and such?
Can someone post some beam shots of this light that show the relationship between throw and spill? I'm interested in the XML2 PDT version with driverVN2.
I know it's a good thrower for its size from Bigwilly's thrower comparison photos. But shots taken for that purpose show only a single distant object as a target. I wonder if the light is useful for general use.
Ok here's some shots of my TX25C2vn XML2 PDTc 4 mode driver. I used my Galaxy Note 5 on auto.Thanks Bigwilly. Anything like a line of trees, not too far away, that would show the spill relative to the hot spot.
My pleasure. It is an awesome torch. It's thermal management is pretty good too given its size and output.Perfect pictures! That's one heck of a little light! Thanks so much Bigwilly!
Nice Pics!
I have the TX25C2vn XPG2 PDT "V3" Direct Drive Single mode version which provides the most throw possible in this light! ~ 80/85Kcd/900 lumens.:thumbsup:
Thanks!
How much more kcd over a DriverVNX2 would the direct drive be worth would you guess?
Just got it today, and holy crap it's awesome!! I also have a stock one, so seeing the difference in tint and throw is amazing!
