maybe it is not real gold!! ^^^^
but it surely smells and looks like gold
Haha. In my head i read that in Smeagol voice.
Does anybody have a Trustfire 10440 battery to see if it fits in this light? They are 46.25mm long and 10.25mm wide. I just ordered the light and want to know if i can get away with the bigger cell. I will probably play it safe but if somebody can confirm that would be awesome.
My concern is based on accidentally turning the light on in your pocket. I've done that a good number of times as the switch sits proud of the flashlight body and can turn on when pressed in a tight area. Yes it would probably heat up and alert you to the fact that it is on, but there is the chance that it could go off in a bag or in a pocket not next to your skin, discharge and go below 2.7 volts if unprotected. People are free to make their own decisions though.
Since the aluminum versions don't have an electronic lockout I'd steer away from lithium batteries I think.
Hope that helps.
At least on paper (cause mine is dead out of the box) there's an electronic lock out function on aluminium K18 - fast double click from off. That's what the manual says.
Funny, I believe I tried that with my wife's aluminum one. Didn't seem to work. I'll give it a shot when she gets home from work. Maybe the newer ones have this feature?
That is INCORRECT. ONLY the SS version has an electronic lockout. I have both versions. Only a physical lock out[twist head] will deactivate the Aluminum versions.
Maybe they sent you the SS user manual by mistake?
I just received my black K18 and it definitely has the electronic lockout. Two quick clicks from off and it is locked out, confirmed with a single flash. Double click again deactivates the lockout and is confirmed with a double flash. Maybe they listened to our comments and made an improvement to an already very nice light.
Can anyone tell if protected 10440 would fit?
When using standard sized batteries, do you have the feeling there's some room left to take an extra 2mm?
I am pretty sure on this thread or in a review someone was able to use protected batteries. I can not recall which oneworked.
I use the Efest IMR 10440. It is a SAFER chemistry and does not need protection. In case of accidental activation simply lock out the light. If the version does not have an electronic lock out,slightly twist the head.
Thanks for responding.
Yeah I know IMR is safer but still not protected against over discharging. The only protected 10440 batteries I know of are the Trustfire brand. Not my favorite brand but perhaps worth a try
Thanks! I didn't know Soshine was manufacturing protected 10440.You just reminded me!! Soshine sell some protected 10440. links below:
