Hamilton Felix
Hmm... if a 194 was somehow installed in place of a reverse lamp bulb with similar base ("oops, it's out, oh here's something that fits"), that would certainly explain a crappy backup light.
The life of the 796 is 1/4 of a 1156
795 is another 1156 option for reverse lighting.
For anyone wanting an incan option for the 921, Raybrig R118 is an 18w(stock wattage) 921 with twice the output.
10 amp fuse on my reverse lighting which is good for 120w.
Not too worried about the 55w bulbs when reversed is used for 2min backing up increments.
I didn't say to use 795/796 as a DRL.
Raybrig 921 bulb that I was given isn't blue. And, I'd say 'one bulb' in reverse put out more light than 'both stock' 921 bulbs.
10 amp fuse on my reverse lighting which is good for 120w. Not too worried about the 55w bulbs when reversed is used for 2min backing up increments
Measure intensities? Why, I looked out my WINDOW.
Oh yes, definitely subjective.
They're made by Stanley in Japan so I'm expecting reasonable quality.
And, the pictures on their website look just a little brighter than what I'm getting. But, the lighting distance is greatly improved.
http://www.raybrig.gr.jp/products/r118_pop.html
I would imagine that the CREE 921 would be spotlights and far too directional with no light to the side. Anyone confirm?
It doesn't matter what Massachusetts says on the subject of reverse lamps-- FMVSS 108 is clear that there are photometric standards regarding backup lamps.for backup lights there are (usually) no laws regarding output and lensing. not illegal. headlights, tails, markers, yes. not reverse lights.
anyway, this is in Massachusetts USA and I looked it up and no violations in Massachusetts with backup lights.
Simplifying things, minimum axial intensity is 80cd, maximum intensity 300cd at any point on or above horizontal, max intensity 600cd at any point between horizontal and 5° down, max intensity 8,000cd at any point below 5° down.
Please don't use this forum to promote unlawful activity.
I need some extra light when I back up. My truck takes a standard 1156 bulb.
