V54 Lumen & Lux Measurements
JMPaul320 Test Results Click Here
The data below is certainly not 100% accurate and every light vary from sample to sample. However these values should give us an idea of what to expect. If they off at least they are all relatively off ;-)
V54 Test Results Below
Turn On OTF Lumen / 30Sec ANSI Lumen
Bold Black = Confirmed with several samples
Factory Lights:
Fenix UC35: 985/960
Fenix LD75: 4150/4015
Nitecore HC90: 930/840
EagleTac MX25L3C 6*XPG2: 2550/2420
Nitecore MH20: 1080/1015
Acebeam T25: 2930/2760
SR96 MKRs: 5140/4850
Noctigon M43 XPG2 CW:
V54 Lights:
ZebraLightS6330vn 3*XML2 U4: 2930/2475
TerminatorVN 4*U3 PDTc + DriverVNX2: 3390/3200
Nitecore MH20vn U3 PDTc: 1015/975
SSvn U3 PDTc 1-Mode: 3390/3450
CTvn 3*XPG2 CW +DriverVN2: 1000/920
M43vn XPG2 S3 3D: 6,340/6,150
M43vn XPL HI V3 : 7400/7280
M43vn XPL PDT V6 : 7800/7660
M43vn Mule XHP70 NW N2 E3: 5600/5470
M43vn Goldilock XPG2s DD: 6000/5930, 107K Max Lux
P60vnT Mule Triple XPL 5700K 3700/3500
P60vnT Triple XPL HI 3,000/2,820
X60vn 2015 5*U3 PDTc: 6550/6310
MM18vn 2*XHP70+U3 PDTc: 7,650/7,450
MM18vn 2*XHP70: 6,760/6,560
MM18vn XML2 PDT: 1,000/9,65
Sample 1: TK75vnQ XML2 PDT+ DriverVNX2: 4,600/4,350, 340K Max Lux, 1170m Max Throw
Sample 2: TK75vnQ XML2 PDT+ DriverVNX2: 4,900/4,350, 366K Max Lux
TK75vnQ Boost Only: 4,300/4,200, 140K Max Lux, 750m Max Throw
TK75vnQ70 SD + DriverVNX2: 14,000/13,300, 210K Max Lux, 920m Max Throw
Olight SR96vn 3*XHP70 CW Shaved Dome + 3DriverVNX2 + Factory Battery : 9,050/8,900,
100K Max Lux, 640m Max Throw
X60vn XML2 PDT: 5,750/5,600, 500K Max Lux
6XPvn: 4200/3950, 175K Max Lux
6XLvn: 5700/5480, 130K Max Lux
TK16vn XML2 PDT: 1100,1030, 46K Max Lux
K40Mvn Boost Only: 3250/3150, 88K Max Lux
LD60vn + DriverVNX1 + XML2 PDT: 2400/2530, 130K Max Lux
K40Mvn MTG2 Dome On: 3300/3050, 94K/87K
T25Cvn + DriverVN2 + XPG2 PDT: 660/610
P60vnG + DriverVN2 + XPG2 PDT: 825/710, 70K/65K
P60vnL + DriverVN2 + XML2 PDT: 1450/1220, 55K/47K
LD75Cvn + XML2 U4: 5400/5250, 90K/87.5K
LD75Cvn + XML2 PDT: 4830/4700, 160K/156K
Factory Lights:
Fenix UC35: 985/960
V54 Lights:
