VB-16 Q5
ernsanada
I just got the VB-16 from Deal Extreme
Shipping took 4 days but from ordering to receiving the light took 14 days to Socal. About the average time items take to get to me.
Cost was $29.00.
Has a Cree Q5.
16 brightness modes, press the first button ("+") to increase brightness and the second button ("-") to reduce brightness (and to switch off).
OP Aluminum reflector with glass lens.
Comes with a lanyard.
3W regulated power output
Powered by 1 x 18650 or 2 x CR123A (3.0V/3.
Comes with a forward clickie.
Comes with Type III Hard Anodize Finish. The finish bands running through the finish with a mis-match of color.
Fit is good.
I just finished lux readings and my VB-16 (SSC P4 USWOI) OP from Waion beats it. I have a thread on CPF Review about my VB-16 (SSC P4 USWOI) OP from Waion.
I thought the VB-16 Q5 OP would beat the VB-16 (SSC P4 USWOI) OP but the lux meter tells a different story. Maybe because the VB-16 (SSC P4 USWOI) has a deeper OP reflector.
In these pictures you can see the horizontal lines running through out the finish.
I used VB-16 Q5 OP, VB-16 (SSC P4 USWOI) OP and Regalight WT1 Q5 SMO Cree in some beam shot comparsions.
Left, VB-16 Q5 OP. Right, VB-16 (SSC P4 USWOI) OP
Left, VB-16 Q5 OP. Right, Regalight WT1 Q5 SMO
I also took lux readings. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected RCR123's and AW's Protected 18650's which were fully charged.
VB-16 Q5 OP, 2 RCR123 - 3430 lux @ 1 meter
VB-16 Q5 OP, 18650 - 3400 lux @ 1 meter
VB-16 SSC OP, 2 RCR123 - 4170 lux @ 1 meter
VB-16 SSC OP, 18650 - 3610 lux @ 1 meter
Regal Light WT1 SMO, 18650 - 10,180 lux @ 1 meter
Regal Light WT1 OP, 18650 - 6,600 lux @ 1 meter
Regal Light WT1 SMO, 2 RCR - 11,350 lux @ 1 meter
VB-16 Q5 OP @ 90"
VB-16 (SSC P4 USWOI) OP @ 90"
Regal Light WT1 Q5 SMO @ 90"
VB-16 Q5 OP @ 90" Stepped down exposure
VB-16 (SSC P4 USWOI) OP @ 90" Stepped down exposure
Left, VB-16 Q5 OP. Right, VB-16 (SSC P4 USWOI) OP @ 90"
Left, VB-16 Q5 OP. Right, Regal Light WT1 Q5 SMO @ 90"
Left, VB-16 Q5 OP. Right, Right, VB-16 (SSC P4 USWOI) OP @ 90" Stepped down exposure
Left, VB-16 Q5 OP. Right, Regal Light WT1 Q5 SMO @ 90" Stepped down exposure
Lighthouse one
Ephrata, Pa
Thanks...I've been wondering whether the new VB 16 was as good as the earlier models...or just a cheaper knock off. Is the quality of the light good...not counting the blemished finish?
ernsanada
Function wise it's good as the others.
I've had problems with the finish on another VB-16. It was a Type III Hard Anodize same color. Had horizontal lines and cracks.
My 1st Gen. VB-16 had a very bad reflector. Many rings, more than a Cree using a SMO.
I think if the VB-16 Q5 had the deeper reflector shown on the right, it would have had better lux numbers.
All the VB-16's had their minuses except the VB-16 (SSC P4 USWOI) OP from Waion. No flaws with that one.
ernsanada
I used my homemade light box.
I used 2 AW RCR123's fully charged on both lights. I waited 2 minutes before I took the readings.
These are my results.
VB-16 Q5 OP - 7760 lux
VB-16 (SSC P4 USWOI) OP - 7200 lux
Tubor
Brighton, UK
Would make a great present if it ran on AA's, maybe 3 for comparative voltage, with a slightly wider body. Like the interface. Thanks for the review.
ernsanada
Is this light waterproof or water resistant at all ? Would be great if it is.
I'm not sure about the 2 varaible brightness buttons. I wouln't want to take the chance to see how waterpoof the buttons are.
fasuto
Spain
The VB-16 from waigon is water resistant, I swam with it in the sea without problems.
Anyway when I really need a waterproof light I use Barbolights or UK
dc
SK, Singapore
Well, looks like the Q5 version does indeed put out more lumens than the SSC P4 according to your test, a great value buy indeed. I hope mine come soon.
DC
ernsanada
How far or deep did you submerge the VB-16 form Waion?
bspofford
Colorado
Ordered mine on 11/7/07, and package arrived yesterday with everything but the VB-16 HAIII Q5 lights. Darn.
Yenster
Texas, USA
Hmmm....ordered mine on 11/8/07 and it still hasn't even shipped. It looks like ernsanada ordered it on 11/13/07 and already received it....hmmmm....
I guest orders with DX sometimes fall through the cracks.
katsyonak
I ordered mine on 11/11/07 and it's been in the status of "Packaged" for several days and then in the status of "Ready for shipment shortly" for several more days (and still is). I opened a ticket and this is what I got from them:
Really sorry that your remaining item 9741 (VB-16 HA-III Q5 Cree 16-Mode Flashlight (1x18650/2xCR123A)) is still unable to be fulfiled due to stock shortage.
Would you mind making an exchange for this ?
So I guess there are stock problems with this item and DX should update their product page accordingly so other people will know that they are ordering an item that is unavailable.
ernsanada
These are beam shots using fully charged Protected 18650's.
VB-16 Q5 OP @ 32'
Right, VB-16 (SSC P4 USWOI) OP @ 32'
