Re: What "Iconic" LED lights have to be put in a "HALL OF FAME FOR LED FLASHLIGHTS"?
Hi, here's my list based on the lamps I've owned: :wave:
HDS Action Light I (1999) (!!)
This headlamp changed the way of thinking how led lamps may (or should) be designed: new shape, three regulated (!) levels of brightness without changing the beam pattern, low level that bypasses the electronics if the latter fail, ...
TechTonique LedLampe (2002)
Several features that were new back in those days:
- 0-100% linear rotary switch (very convenient to use)
- glow-in-the-dark board behind the leds (so that you can change the batteries)
- regulation
Speleo Technics Nova (2003)
Another caving headlamp! The Nova introduced the Luxeon V led. Wow! one single led that is so bright!
Moreover the lamp was easy to use and the battery easy to replace (compared to other period caving lamps); the concept of this lamp is interesting since they made it compatible with their other incandescent products, e.g. the battery is the same (so you can keep yours or exchange it with another caver).
LedCorp Epeion (Luxeon I bulb for Maglite) (2002), TechTonique Duo LedLight (2002), various Terralux led bulbs for Mag, Diamond bulb, ...
They introduced the concept of retrofitting a flashlight or headlamp to save costs and benefit from a solid body.
Terralux tried several concepts (some were stupid and some were brilliant), so IMHO they deserve to be mentioned here.
TechTonique used both "wide" and 20° 5mm leds in their modules, while others used only the common 20° version. But the customers didn't like them so thereafter they only used the 20° version.
TechTonique also introduced warm-white led modules (still using 5mm Nichia leds).
Petzl Tikka (first version with 3 x 5mm leds) (2001)
This small headlamp made the general public (especially hikers, even occasional) discover white leds and their benefits compared to incandescent.
Furthermore Petzl conceived a small headlamp that didn't intend to equal nor outperform incandescent, which was a quite new concept.
Arc4 and HDS EDC Ultimate Flashlights (2004)
Do I need to explain why?
Scurion (2007)
Several features that made this programmable caving headlamp another must-have for flashaholics:
- 5-bar battery status (5 green leds), very useful to manage runtimes when caving underground
- bare led giving a 180° wide spill beam comparable to an acetylene headlamp (in addition to a second collimator spot beam, without spill) (both are independent)
- optional 5mm led (you can choose between amber, red, UV ... colour) for underground camping or urban exploration
Zebralight
We all know this innovative brand that changed the shape of headlamps and made wide angle beams affordable (I'm thinking of the H501, while a Scurion has always costed several hundreds of bucks).
Armytek Predator (2011)
Programmable regulation (stepped, flat, linear decrease) is a must-have for geeks!
One more thing: I'd like to mention the great
SSC P4 and
Cree XP-G 90+ CRI leds that made led flashlights offer the same quality of light as halogen bulbs.
