The only superior features on the CRF are size, weight, 8% larger exit pupil (this is very minimal) and single shot accuracy when handheld, compared to the 1200 model on single shot. Since the CRF is more ergonomically designed as compared to the square style, the lasing button only requires half the depression force resulting in less shaking when handheld.
Compared to the CRF he 1200 Scan is slightly larger, (the size of a sandwich) a few oz heavier, and has one more extra external lense to keep clean. (3 instead of 2) The 1200 Scan is less accurate on a single laser shot although that's not really an issue since both models scan. The 1200 Scans 9V battery lasts quite a bit longer than the CRF's CR2, especially when used with a lithium.
Quite honestly, the 1200 Scan is a better value. Unless you need your rangfinder it fit into a small, breast pocket there isn't much of a point to spending the extra money on the CRF.
Note: The Leicas will sometimes range further than 1200 yards. I've ranged a house at night time at 1342 yards. Depending on conditions you may occasionally see performance exceed specification. Leica does not overate their specs like some companies. They under promise and over deliver. I like that!
