Alaric Darconville
I've 'broken' two of these things, one was a 300/600W "Roadmaster" that got very light use, and the second a 350/700W Coleman job that also got very light use. When the second one failed, it was just charging my wife's Kindle-- and then started beeping like mad. (Earlier in the week, I'd been using it for a heating pad on my lower back, around 50W, so I didn't think the Kindle charger would have done it in, unless it was something to do with the square wave or stepped approximation to sine wave the inverter put out.)
Recently, I dismantled it, and I think one of the diodes must have failed, since I could get a continuity beep no matter which way I put the multimeter leads on it. The capacitors all looked good, and I didn't smell any obvious burned smell.
I then hooked it back up to a battery and turned it on-- it beeped like crazy-- and let the magic smoke out . Good thing I was in the garage.
Before I buy another one, what brand would people strongly recommend? I'd like a minimum 350W continuous/700W peak, and would most likely use it in a cigar lighter socket. Probably the heaviest duty I'd have it perform would be to run a <40W heating pad or maybe <150W electric blanket in the winter.
