Which battery charger?
jcr71
Please recommend me​ a good battery charger.
Mainly for 18650 batteries, i charge 4 of this type once or twice a day. They get used for vaping. Also the occasional NiMH batteries from torches, remotes etc. Have been using an intellicharger i4 for about 3 years and now it's starting to play up. The 3rd lane has stopped working altogether and it doesn't always recognise when a battery has been inserted.
Many thanks
Jason.
Repsol600rr
But vp2s don't do nimh. I would get an xtar vc4. Does 4 18650s or nimhs at 500 ma which is better than what your i4 did. It can do 2 at 1 amp. There is a thread on it by hkj. Read that. Make sure you have/get a good walwart and it should serve you well. If you want more speed and features then something like the liitokala lii-500 or the opus bt-c3100 v2.2 are other good options. I'd look up those as well. I have the 3100 and the vc4. Both have been serving me well. Plenty of info in the batteries sub forum.
Timothybil
The great state of Misery (Missouri)
I'd recommend a pair of XTAR VP2's.
The VP2 doesn't do NiMH. I use mine for my 10440 and 14500 cells since I can set the charging rate at 0.25A, which is better for the smaller cells than the 0.5A my VC4 offers as a minimum. As much as I like both of my chargers, I would recommend that you get one of the chargers often mentioned here that does capacity measurement as well as the usual charging. There are times when I wished I had that capability. From comments others have made, I don't believe one of those chargers would be much more, if any, the the Xtar VC4 I mentioned. [Shock! Gasp! Me recommending something other than Nitecore! The world as we know it is no more! :ironic: ]
PS: Sorry Repsol600rr. I hadn't read your reply yet when I wrote this. But doesn't hurt to have a second opinion agree with you.
roadkill1109
From best to ok (1 to 5)
1. SkyRC MC3000
2. Xtar VP4 Plus Dragon
3. Opus BT-3100
4. Liito Kala Li-500
5. Nitecore SC2 (soon coming out SC4)
ven
Manchester UK
Opus bt c3100 v2.2 gets my vote for value and flexibility. Nimh support, 1a x4 bays, up to 2a on 1+4 bays for quicker charges. Lowest is 0.2a for small cells..........
jcr71
Than you for all the replies. I shall look at all the chargers mentioned.
tatasal
+1
TinderBox (UK)
England, United Kingdom
The Opus C3100 is also sold as the Opus 3400, also it might not be branded as Opus, mine is an Floureon BT-C3100, there are at least 3 re-brands, depending on where you live in the world for availability and price.
I just search for C3100 or C3400 charger to cover all brand names.
John.
markr6
+ eleventybillion. It's all I use anymore...for everything.
Mr Baz
If you don't need to more advanced features the D4 and VC4 re pretty solid I did a comparison here: To date they are the most consistent I have tested the new i4 is OK for lithium not ideal for Ni-MH new i2 the same both seem to under charge. My vote is the D4/VC4 or possibly the VC2 plus Master
Capolini
Banned
Valley Forge, Pa.
iirc neither of the above can charge ALL 4 slots @ 1A. For me that is a must. MOST of my batteries are 18650 and I have several 3 X 18650/4 X 18650 lights.
My Fenix ARE-C2 is one of the few chargers that comes OFF the charger @ 4.20V. Also the fastest!
My Opus/Efest and KP models come off @ 4.16 at best,,then of course they settle several hundredths of a volt!
1.Fenix ARE-C2
2.OPUS BT-C3100
3.K'Power L2
4.Efest LUC V4
We all have different criteria and preferences! ;)
vadimax
Vilnius, Lithuania
From utilitarian point of view Xtar SV2 needs its larger brother -- SV4. SV2 is excellent in my point of view: .25A for small cells, 2A for large ones. Xtar "proprietary" low termination current... What might be best? :)
Tachead
Northwestern Ontario, Canada
Another one that can NOT display all 4 slots at once! :poke: At least 2 is better than 1!
It is only a quick button click to swap between displayed banks and it has a nice large easy to read display. Personally, I like it better then other chargers I have used that do display all 4 banks at once.
