...Finally, if we want to compare the total cost between regular and XX, we have to take into account that e.g. a regular one will be replaced let's say after 500 cycles whilst an XX probably sooner i.e. at 250 cycles, also taking into account the more capacity per cycle for XX. That means, when we buy our 2nd set of regular eneloops, we'll buying our third set of XX's. This wasn't taken into account at the initial post so the cost difference results might not be that trivial but I honestly don't think the case is the overall cost, it is mostly the reliability aspect and XX's don't have that long history yet to indicate they are at least close to regular eneloops robustness...[excerpted]
Your point about cost is well taken. And, while I realize that your final point goes more to the issue of "robustness," since I had a bit too much free time on my hands, I decided to attempt to model the costs in a bit more detail. Here are my results:
First, just to be clear, I am taking the Standard Eneloop (4th Gen.) and comparing them to the Eneloop Pro (3rd Gen.) which are the two types that are currently available here in Japan.
Their stated maximum capacities are 1900mAh and 2400mAh, and their stated maximum number of cycles is 2100 and 500, respectively. Without taking any loss factors into account, a 500mA load should yield 3.8hrs and 4.8hrs, respectively. Meaning, that if the Eneloop Pro manages to function with good performance (reasonable performance?) for 100 cycles, then the Standard Eneloop, used in the same application must be cycled approximately 126 times to achieve the same aggregate runtime.
Now, for the time being, I am assuming a recharge cycle of once per week (52 times per year) for the Eneloop Pro, which translates into 66 times per year for the Standard Eneloop, since it must be recharged that much more often to achieve the same aggregate runtime.
Also for the time being, I am assuming that the maximum useful life of both batteries is the same (when expressed as a percentage of the stated maximum number of cycles). In this case, I am using 20% for both cells: 100 cycles for the Pro Eneloop, and 420 cycles for the Standard Eneloop. (I recognize that this is a highly questionable assumption, and the Standard Eneloop may likely have a longer useful life, even when expressed as a percentage, but we will get to that later.)
The cost of a Standard Eneloop cell in my market is about $2.91. And an Eneloop Pro costs about $3.28 (or 12.7% "differential", meaning $0.37 more). But, since I know that Eneloop Pros can cost "double" in some markets, I am also doing the same calculation for an Eneloop Pro that might cost $5.82 (or 100.0% "differential", meaning $2.91 more).
If you assume (for the time being) that Standard Eneloops are good for "only" 420 cycles, at 66 recharges per year, that translates into 6.4 years. And over the course of that same 6.4 years, if you choose to use Eneloop Pros, you will find yourself replacing your Eneloop Pros 2.3 more times to achieve the life of the Standard Eneloop. (In other words, 1 x Standard Eneloop = 3.3 x Eneloop Pros.)
Now finally getting to "total" cost: with the 12.7% price differential, the Eneloop Pros will cost you a "total" of $10.90 each, over the course of those 6.4 years. And, at a 100% price differential, they will cost you a "total" of $19.35 each. (Without taking inflation, or other similar factors into account
Granted, this may not be an insignificant amount of money, yet it is over a
6.4 year period.
And, as has been a significant reason behind my originally starting this thread, when viewed in terms of
cost per cycle, the costs are $0.007 per cycle for the Standard Eneloop, and $0.026 per cycle for the Eneloop Pro (12.7% price "differential") and $0.046 per cycle (100% price "differential"):
neither of which strike me as unduly burdensome.
Anyway, I also "fooled around" with the numbers some. Best I can tell, changing discharge rates, or frequency of recharging has no real effect. (If you are a heavy user of batteries, you will find yourself spending more on batteries over time.)
But, having read the many well considered posts in this threat, I too, am concerned about the ultimate "robustness" of the Eneloop Pro. So, I do feel it may be unfair to the Standard Eneloop to use the same 20% of stated maximum number of cycles to reflect their true useful life.
So, I tried using 30% (or 630 cycles) and even 40% (or 840 cycles), with the result of their battery life being extended to 9.6 years and 12.8 years, respectively. (I honestly don't see myself being worried about batteries that I purchased in 2013, when it gets to be 2025... do you? (I realize, of course, some people do recharge very frequently, but I believe most people don't.)
Anyway, the cost per cycle of the Standard Eneloop drops off to $0.005 and $0.003, respectively. But, since their number of useful cycles is being held constant, the Eneloop Pros still cost "only" $0.046 per cycle, even though you must purchase 6.7 times as many (given the 40%) scenario above, over a 12.8 year period. (Don't forget, you get the automatic "added bonus" of having 5.7 --less than perfect, but probably still "useful?"-- batteries laying around.)
I guess, what I am really trying to say (again) is:
"Isn't it worth a nickle per cycle to you, to get use the battery of your choice on a daily basis?"
In my opinion, the cost of batteries (no matter which type you decide to buy) seems like a fairly minor cost when compared to what most people spend on food and drink, or putting gas in their car. Yet, I see them as equal necessities. (So, why "scrimp" on batteries?) I like the longer runtimes of the Eneloop Pro. Especially, the longer runtimes at the end of one year without recharging.
But, I will add this: Having read everyone's posts, if I find my Eneloop Pros failing suddenly, and/or catastrophically, I will be the first to go out and purchase me some "tried-and-true" Standard Eneloops (assuming the 4th Gen. is a good as the 1st, 2nd, and 3rd have apparently been).
In the meantime, I have tried to start off "right" with my new Eneloop Pros, and I am using my new MAHA MH-C9000 to perform Break-In and Refresh-Analyze on them "out of the package." And, I am keeping accurate records. So, in a few years, I should be able to report my own experiences.
In the meantime, if you managed to get to the end of this... Thanks for listening!
