NewBie
*Retired*
jtr1962 said:The meter is supposed to be within 10%, so I assume this is the upper bounds of my error. In practice, based on my relative measurements in Silverfox's light meter benchmark testing, my light meter is reading maybe 5% high for white LED type light compared to the average (although the average isn't necessarily dead accurate).
Unfortuately, the majority of the error is in the spectral response. These meters are "calibrated" for incandescent, sodium vapor, fluorescent, and such. Some have correction tables built in you select the type of light source, to adjust for the error, others have the correction factor in the manual that you have to apply manually. Read your manual, if it worth beans at all, they will mention those correction factors (the LM631 is only accurate for tungsten lamps as I recall).
An example is one of the higher end, unfortunately more expensive light meter (though it is not accurate for LEDs):
http://www.extech.com/instrument/products/400_450/407026manualregist.html
Unfortunately, nobody I know of has created a spectral correction factor for white LEDs, and that would be somewhat futile, since the white led spectrum varies from white LED to white LED, even from the same manufacturer.
One of the few instruments that can remove this *very* significant source of error is a spectroradiometer, and they are darned expensive.
