[ QUOTE ]
illumiGeek said:
Yes, copper absorbs heat better than aluminum, but it sheds it slower. Remember, the heat has to go somewhere.
Aloha, iG
[/ QUOTE ]
I'm not sure I can agree with you on that point. It will depend alot on the surface characteristics and the finishes that are applied.
Thermal Emissivities from one source (higher is better):
Aluminum foil 0.04
Aluminum disc (rough grooved finish) 0.18
Aluminum household (flat) 0.01
Aluminum polished 0.04-0.06
Aluminum highly polished 0.035
Aluminum (rough plate) 0.06
Aluminum (oxidized) 0.11-0.19
Aluminum (anodized) 0.55
Aluminum (weathered to point of pitting) 0.57
Aluminum carbon coated 0.84-0.98
Brass (polished with machining lines left in) 0.04
Brass (highly polished) 0.03
Brass (quite tarnished) 0.22
Copper (machined surface) 0.18
Copper carbon coated 0.84-0.98
Copper (plate heavily oxidized) 0.78
Copper (polished) 0.02
Copper (oxidized black) 0.89
Nickel (polished) 0.072
Nickel (polished electroplate) 0.05
Nickel (oxidized) 0.37
Nickel oxide 0.59-0.86
Silver (pure, polished) 0.0.020-0.032
Stainless Steel (lightly buffed) 0.14
Stainless Steel (sand blasted) 0.46
3M Black Velvet 9560 1.0
Thin coating of Krylon Ultra-Flat Black 0.97
Krylon High Heat Barbaque paint, after heating 0.99
As you can see, polishing greatly reduces the thermal transfer into the air, which would cause the light to get significantly warmer.
Here is another page, which includes the emission wavelengths (thermal emissivity changes depending on the temperature of the material):
thermal emissivities
