ss2nv
I am doing something like Sylathnie's Sublimator. I want to know if ya'll think this switch and socket setup will take the heat. I am planning on using the brass slug that FM offers with his 6.35 sockets, only I found a different socket to put in it. I got the socket from LightBulbsDirect.com. It is supposed to handle 750 watts and 250 volts. The positive will run through an automotive rocker switch that I got from RadioShack. It is supposed to handle 16 amps and 125 volts. I got this idea from another member here, though I can't remember who it was. The negative will run through the body of the light and make contact with the brass slug. I am going to sand the finish off of the throat of the light so that the circuit will make. I want to get feedback if this will work before I go sanding on my Elephant II...
Anyway, here's the pics:
