Worlds Longest Running Bulb 108 years
Nubo
It's right around the corner; I keep meaning to go take a peek before it finally blows!
For anything we'd consider a "useful" incan light, Tungsten rules. But at very low wattage, the carbon filament is well-suited for extreme longevity. This bulb was made when carbon filament technology was at its zenith, right before Tungsten took over.
aginthelaw
NJ, USA
See you in 2026 at the 125th anniversary. I can't believe my grandma died right before the 105th anniversary she was also born in 1901
thermal guy
ny
So I'm assuming it has not run continuously all this time has it? I mean power outages and such.
broadgage
Somerset UK
Another example of how things were done back before America became a disposeable society. Even the bulbs were made to last.
Misleading IMHO, a modern incandescent bulb could easily last 100 years or more by underunning it sufficiently. A 277 volt lamp worked on a 120 volt supply should last a century.
A good qaulity carbon filament lamp run at rated voltage should achieve about 2 lumens per watt. A lower qaulity and very under run carbon lamp such as a 277 volt or 300 volt lamp run at 120 volts might be only 0.1 lumens per watt.
A modern tungsten lamp will be from 10 lumens per watt up to 20 lumens per watt depending on voltage, wattage and design life.
A modern LED lamp will reach 100 lumens a watt, and 200 lumens per watt lamps now exist.
Whether 100 years ago, or more recently, most people hate buying light bulbs and complain when they have to buy another. The cost of electricity far exceeds the lamp cost, but most people worry far less about that.
Here in the UK there was a fad a few years ago for "everlasting light bulbs" these were not truly everlasting but were very long lasting. The suppliers promised to replace any failed lamps for free if the customer paid for postage.
These long lasting lamps were significantly dimmer than proper 1000 hour incandescents and required about twice the lamp wattage for a similar light. They were popular with people who could not understand the cost of the extra electricity used.
