ven
Re: WTS: TK75vn 4400L
Awesome pics mr Tmack thanks for sharing:thumbsup:
I sent funds - please put me on the list for opt b :rock:
Sent from my ihateapple droid device.
Actually I paid$9 and just switched my k50 order hehe
Ah ok... Wow U are up late!
I don't think so he said the list here on CPF was for back orders and he had them in stock
Dedome is removing the clear dome from the top of the led. It dramatically increases the throw, but slightly decreases overall lumens. It also makes the led tint warmer.
I find the carrier not as tight as my tk51 carrier(very similar but 3 cell instead of the 4 cell on the tk75).
The tk51 is tight,as an example using the same cells pany 3400 protected i find easier to remove out of the modded tk75vn carrier:thumbsup:
mmmm not too sure,iirc the older xtar 18700 will
My sanyo protected are around the same as the pany cells,give/take 0.1 mm as those are a similar fit.
I am sure most are made to fit up to 70mm,however that extra 1mm over the 69mm cells make it that bit tighter due to the spring being more compressed.Strong nails (i bite mine)or as i do carefully with a flat edge to remove cells,issue free:thumbsup:
Fresh off the press for you
XTAR 2600 and pany 3400 both protected and can see the pany are longer
Without exact measurement can see around 1.5mm gap with pany 3400
tk75 carrier left and tk51 on right,even though the xtars in the tk51 carrier are a little shorter they are still more difficult to remove
So there you go,room for a 70mm cell if needed,just be a bit tighter.......
Hope of some help:thumbsup:
