Wuben E7 Torch Review
TimMc
Melbourne, Australia
Wuben kindly sent the E7 for review.
There's an optional headband, optional sensor for handsfree operation, and an optional 18650 extension tube.
It's a bit like the Wuben X0 but there are some big differences.
Here is my review:
TimMc
Wuben kindly sent the neutral white version of the E7.
5000K
The CCT of the Wuben E7 Neutral White is around 4917K. The CRI is around 69.
The Delta u, v is positive (green).
ModeCCT (K)CRI (Ra)xyDuv
Low481869.10.35160.36610.0046
Med491269.30.34870.36480.0051
High492569.20.34830.36410.0049
Turbo501569.70.34540.35990.0040
TimMc
If you have a Wuben E7, DO NOT insert an unprotected cell in reverse!
An unprotected cell may be shorted if a battery is inserted in reverse. This will damage the driver and it could cause a fire.
The included protected 18350 cell works as expected and did not get warm or damage the driver.
I inserted an unprotected 18650 cell in reverse, screwed the tailcap on, and the torch started to smoke! The driver has been burnt and no longer works.
The Wuben E7 should be recalled
While reviewing the Wuben E7, I noticed the tailcap spark when I tried to put the tailcap on with an 18350 cell inserted in reverse but nothing else happened. I asked a few community members and they weren't able to reproduce this issue.
Wuben sent a second Wuben E7 (neutral white). This time I tried to insert an unprotected 18650 cell in reverse and the driver started smoking. The torch became warm to touch and it no longer works.
