now that ive been an owner for half a year (and the popularity of this cpf thread lead me to buying it!!) here my thoughts. nobody asked for it but i am good.
- i dont mind the flickering issue when the light is ON because i solved the problem with the WD40 bath. tapping the switch in a decided manner helps too: no more flickering! slowly pressing the switch (for what reason please?) will cause flickering .. because *you* are causing then the flickering literally and mechanically. lol
- the fenix ld20 pocket clip has scratched the red anodization. i use the clip for bezel up carry (attached to pocket or to baseball cap; works beautifully)
- everything of the tail switch is apparently cheap: the black plastic retainer, the ridiculous weak spring, and the el cheapo clicky. i do like the black rubber boot and tailstand capability. and that all fenix ld20 21.5mm addon's (diffusers, ..) fit.
- i didnt like the creamy-yellowish tint of the XML T5 NW. but after 6 months i like it fwiw. all my other lights are pure white or coolwhite so having 1 light which is warm.. yah why not.
- i am missing mode memory.
- tactical momentary on isnt possible with this light because activation is used to progress in the mode sequence. one would need a twisty head to incorporate tactical momentary on.
- the light is waterproof. 10m. thanks to the 2-part system (tail + tube) and double o-rings.
- the brightness is not stabilized on High-mode. no matter with Eneloops or 14500. similar to iTP A3 which isnt stabilized on High-mode either. here's room for improvement.
- my 1xAAA lights with 10440 beat the Xeno E03 on Eneloops in brightness and also in
lumen-minutes.
the biggest gripe i got .. and only after using the E03 for 6 months i am realizing this:
- on 14500 you dont get any serious runtimes. for serious illumination tasks (e.g. illuminating a chess board for the duration of a chess match) the E03 is a big fail. On Med-mode@14500 we get max. 60mins from the E03, whereas on Hi-mode@14500 i get 120mins from the Quark X. The Quark is a serious flashlight for serious tasks. Easily. I cant say this about the E03, sorry. In RL situations when i have to pick a compact light for a serious task (e.g. cleaning the house) i have stopped picking the E03. The runtimes (and lumen-minutes) are simply too disappointing. Eats 14500's like there is no tomorrow.
the E03 XML is a truely inefficient light. for EDC situations not a big deal, for serious lighting tasks a nogo. For the latter you'll long for a more efficient flashlight (Fenix LD20 or Quark; they are more expensive but.. )
