Zebralight H51w is too dim. Is the H51 cool white better for trail running?
beamis
Southern California
I realize that this isn't a test that can be used to authoritatively measure the output of all lights, but since both lights in this case have very similar beam patterns and reflector sizes the relative difference between them is still valid. The data from these readings correlates not only with my initial assessment of the relative brightness between the lights, but also with 4Seven's lumen ratings. It would be a pretty amazing coincidence to have a Zebralight look dimmer than a Quark by about 50 lumens, read dimmer on the lux meter by just what you'd expect for a light about 60 lumens dimmer than the Quark, have the Quark read at values that one would expect for the rating claimed by 4Sevens, and actually have it turn out that all of those observations and measurements were wrong. I'm not saying it's not possible, but it's going to take a lot more than second-guessing to knock cold, hard data in my mind. I'm going to see if I can borrow the meter to do a ceiling bounce test or some other form of test on reflected light. I'll have to do it fast though because I've got an RMA on the Zebralight.
123 lumens is only 70% as bright as 181 lumens.
moldyoldy
Maybe Wisconsin, maybe near Nürnberg
The sensor is larger than the head of both lights. Essentially all of the light is going into that sensor (minus some trivial amount reflected away, but the sensor should be calibrated for that). Even if the lumen calculation is off, the relative difference is undeniable. The Quark is definitely 47% brighter than the Zebralight.
Another thing to note is that the value for the Zebralight never stabilized, it just kept dropping and dropping. I just snapped the picture after about 30 - 45 seconds (and it had dropped about 15,000 lux in that time). If I would've waited for the full ANSI specified time of three minutes I'm sure it would have been even dimmer.
If your perceptions are correct, your NiMH cell was not able to source the continued high current draw of the Zebralight w/o an excessive voltage drop. I have measured the current draw on several of my Zebralights (SC51, H51, etc.) and I routinely observe levels of 2.5+ amps. That is rather a lot for an AA cell. There are not many NiMH cells that can souce 2.5A-3A without excessive voltage sag.
As a quick check, when the light is on high, double click from H1 to H2. If the difference is not obvious, the AA cell is not supplying the necessary current.
In any case, before such tests, the cells need to be fully charged to cutoff. Comparisons are especially troublesome with cells of varying discharge levels. I find remarkable differences between ostensibly similar output lights - all due to cells discharged beyond some 10-20% of capacity, meaning a run time on high of maybe 10 minutes from coming off a charger.
moldyoldy
and in answer to a possible question, I have an SC51 from before the driver update and one from after the driver update. There still needs to be an easily observable output change between H1 and H2. Otherwise the AA cell is not supplying sufficient current at 2.5+ amps. The H1 & H2 difference with a fully charged battery with the new driver is admittedly greater.
reppans
...There still needs to be an easily observable output change between H1 and H2. Otherwise the AA cell is not supplying sufficient current at 2.5+ amps. The H1 & H2 difference with a fully charged battery with the new driver is admittedly greater.
I can see an obvious diff between the H1 and H2 on my H 51w still no comparison to a Quark S2
The R5 AA^2 is rated at 205 lumens, the S2 would be about... 220.
I have an S2, it was a limited edition, FourSevens rates it 180 by their their own specs - just confirmed on the box.
beamis
Southern California
If that's what's happening here we're going to have to re-evaluate everything we know about Eneloops because this was a new Eneloop with less than a dozen cycles on it fresh off the C9000 (after two hours top-off).
This light has several H2 levels, depending on how you program it. All levels are perceptively different.
Fresh off the C9000.
All you have to do is have these two lights in the same place at the same time and I guarantee you will not be able to say they are of equal brightness. Some say that cool white looks brighter than neutral white, but don't forget that lumens measure what humans perceive, not the actual quantity of photons.
moldyoldy
Beamis: some more fishing for explanations... My first caveat is that when I do not understand a perceived problem, it is usually because I have more than one problem. :)
as I recall, there were some versions of the C9000 that did not fully charge a cell - requiring at least the 2 hours trickle charge to supposedly bring the cell up to full charge. I had 2 C9000s and disposed of both of them because of inconsistent results between the C9000s. However that 2+ hour difference in trickle charge should not have that significant of an effect in output.
New Eneloops with less than a dozen cycles? well, agreed, at least they are not new with only a couple cycles. My Eneloops have significantly upgraded capacity after a few cycles.
The light sensor has a sensitivity spectrum. Have you checked on the sensitivity accuracy of the sensor across a visible light spectrum? that data may be on the manufacturer's website somewhere.
Just for my own edification, I pulled out my H51fw and H51f to compare them. To my Mark I eyeball, the "w" version is distinctly dimmer than the "f" version although per spec there is supposed to be only 190-164 = ~30 lumens difference. and not just a little dimmer, a lot dimmer.
Why not attempt the ceiling bounce test? That is still subject to visual perceptions.
FWIW, I personally do not like the "w" or "warm" version of just about any light brand. too warm and to my perceptions - too dim. Probably the only neutral version that I thought was reasonable was the Fenix LD40.
Good luck!
beamis
Southern California
I think there might be some confusion about what a "lumen" is measuring (light meters typically read lux, which is 1 lumen/m^2). A lumen is NOT a quantity of light, but a measure of how strongly a human will perceive the light. In other words, lumens are independent of color. Lights of equal lumen ratings will appear equal in brightness regardless of their color. A purely blue light has to generate almost ten times as many photons as a purely green light source to achieve the same lumen rating. A meter designed to measure lux/lumens should not be equally sensitive to all wavelengths because human eyes aren't.
Then somebody is fibbing on the lumen ratings.
Good luck!
Lumens are measuring visual perceptions, that's why lights of equal ratings should appear substantially equal regardless of color.
srfreddy
New England
Some people "perceive" cool light to be brighter than neutral light, even at the same lumen levels. Lumens are based on human sensitivity of wavelengths, but light meters are calibrated to different sources of light, which have different wavelength patterns (Fluorescent, incan, led, HID, etc.)
foursevens.com says that the R5 model is rated at 205.
moldyoldy
beamis: Fibbing? ummm, well, since my perceptions of "brightness" of non-cool-white LEDs are generally too consistent across brands of lights, I would rather wonder about the testing method and equipment used by the manufacturers of any lights with non-white beams, including CREE itself. I doubt that any of us have equipment that could even touch the spectral resolution and accuracy of their light sensors. noting that accuracy and resolution are not the same. Accuracy normally depends on a caibration ratio to NIST, usually a 4:1 ratio, which for a handheld device is usually no more than a yearly calibration cycle. Once upon a time I owned a very expensive photographic light meter (several hundred $$) that would measure ambient light as well as the light from an electronic flash, pulsed or steady-state. The settings were not the same for the different colors!
moldyoldy
beamis: back to your statement that the light output from the Zebralight was continuously dropping after turnon. That alone is a problem.
I have several Zebralights as well as multiple Fenix, Sunwayman, Nitecore, Lighthound, etc lights. With the exception of the Lighthound AAA lights running single 10440s, all of them will hold a perceived constant output for at least as long as the 3 ANSI minutes.
Assuming that the output dropping condition is repeatable with different AA cells, then the RMA is fully justified.
I have used the RMA process several times with different vendors including Zebralight with no problem in the results. Only that the process was slow! Good luck!
srfreddy
New England
Sure.... no one's doubting that. I was addressing your post here:
Beamis and I have the Quark XPG S2 which is 180, and we were comparing output to the 172 lm H51w.
But it isn't 180, unless you're telling me that the R5's are brighter than s2's in which case we should be pointing fingers at cree.
reppans
I'm sure they can tune the driver to whatever they want.... perhaps this is tuned for efficiency and ultimate runtimes.
beamis
Southern California
When I say fibbing, I mean claiming a higher brightness than is reality whether by intention or accident.
I can't comment on the QC abilities or procedures for any of these companies because I have no idea what they are. I can tell you that I used to work in a shop making aerospace parts with tolerances of 0.0001" and the plant regularly failed to inspect anything, or maybe one part out of a run of 500, and just flat-out lied on their QC certifications. I'm not saying Zebralight or Cree, or anyone else for that matter, does this. I just want to make the point that just because a business should doesn't mean they do.
I can't imagine a meter designed for measuring flash output was measuring lumens/lux since film and digital sensors do not respond to light the way human eyes do and such readings would have little meaning for photography.
beamis
Southern California
I can't detect the falloff with my eye.
Mr Floppy
42 minutes, I don't think it is for that. I think it may be ANSI ratings with the S2 and non-ANSI ratings with the R5.
Wow, 2.5A, I'll definitely use an Eneloop then, maybe one of the older ones.
