recDNA
- Joined
- Jun 2, 2009
- Messages
- 8,761
Don't forget in a high powered flashlight CR123A voltage sags. I'm not saying to do it or that it is safe but in H1 no way 2 x CR123A are at 6 volts. I don't know how much they sag but certainly below 6 volts. Still, no question excessive voltage could damage circuit and the vf of the led is below 6 also. I know I wouldn't do it. I won't even run the sc32w which is designed for a single primary on H1. The battery gets hot. I don't like that.Fairly familiar with PID working with it in much larger applications everyday. The feedback from the temperature (sensor on the main board somewhere) is driving the emitter output. I would be more worried about the 6+ volts of 2 CR123s in series letting the smoke out of the electronics than any indirect heat (if any) the batteries might create. A PID loop is simply regulating an output based on closed loop feedback, not protecting a circuit from overvoltage or current. I'd think your board would go poof before your batteries affect the process variable, the temperature in this case.
If the new sc63w is rated for 2 x CR123A I will buy one and run it at H2 max. I do not want to draw 3 amps from primaries in sequence.
