Zebralight Reliability Poll Revised for 2012
Have you had any trouble with your Zebralight
  • No trouble w/ my H501/H501w with press fit switch
    Votes: 30 21.1%
  • Yes, had a failure w/ my H501/H501w with press fit switch
    Votes: 10 7.0%
  • No trouble w/ my H51 (all variants)
    Votes: 64 45.1%
  • Yes, had a failure w/ my H51 (all variants)
    Votes: 8 5.6%
  • No trouble w/ my H31 (all variants)
    Votes: 30 21.1%
  • Yes, had a failure w/ my H31 (all variants)
    Votes: 8 5.6%
  • No trouble w/ my H600/H600w
    Votes: 24 16.9%
  • Yes, had a failure w/ my H600/H600w
    Votes: 15 10.6%
  • No trouble w/ my H502/H502w
    Votes: 13 9.2%
  • Yes, had a failure w/ my H502/H502w
    Votes: 6 4.2%
  • Total voters
    142
  • Poll closed .
Owen
AL
I was supportive of Zebralight in the previous thread. For some time now, they've been the only Chinese manufacturer I would even look at, but my experience with them has quickly gone downhill, and they won't be seeing any more of my money.
I ordered a "new UI" H501w, having been satisfied with my other ZLs, and it would flash briefly then turn off when activated. Returned that one for a refund.
The H60w I'd been getting dependable use out of for some time at work screwed up-water under lens, and circuit failure due to water ingress.
So I put one of my two H30ws on my hardhat as a temporary replacement for the H60w-malfunction due to water ingress a few nights later in its first heavy rain, modes not working, turning itself on and off. It started working again after drying out, but obviously can't be trusted.
Those last two are both out of warranty.
My SC30w worked fine, but was lost in three days due to the clip and short body, I guess.
SC51Fw and other H30w continue to work fine with regular use. 'Course they haven't been used in the rain.
Disappointing to say the least, and an embarassment, because I've recommended Zebralights to other people.
They've been wonderful users with their floody beams, consistent color temps, excellent materials, machining and anodizing, and I thought highly of them, but reliability of the circuitry and waterproofing obviously just isn't there.
I won't count the SC30w, so will say I'm now at a 60% failure rate with 5 Zebralights, and 100% failure rate of ones exposed to the elements.
That's not just bad, it's pathetic. Would have had three more by now, but so much for my favorite brand...
varuscelli
Texas
Owen: It's discouraging to hear about those bad experiences. I've been lucky with the Zebralights I have, but that's really concerning in regard to the waterproofing issues. I've never actually put mine through the ringer that way, but certainly if you need a headlamp that's waterproof (or in the very least highly water resistant) and you buy one with that characteristic...and it fails to perform up to stated standards...that's surely a major reliability issue.
michman
Toronto, Canada
I am really happy with my ZL 501w and H51(f)w's. I only wish that the H501w gave a bit more warning before the battery dies...
Bolster
Mexifornia
I wonder what the base-rate for failures is, across the board, for all brands. I was just reading the Surefire Maximus, Minimus AA... thread and was noticing all the complaints of failures there, too. I wonder if there are any headlamp brands that are hardier than others, or are they pretty much all the same, on average. Dunno. They all seem to have plenty of reported failures. Makes me more and more of a "two is one" guy.
pounder
I 've had my h31 for 15 months now and no issues at all..it works as failthfully as it did on day 1..i've since bough an sc600 and h600..both work perfectly although i've only had them 3-4 months..love zebralight
B0wz3r
San Francisco Bay Area
I have four different ZL's, an SC50w+, an H51w, and SC60w, and an H51Fr, and not had a single problem with any of them. I've had my SC50w+ for nearly two years now and it has been a faithful and reliable light and it's been through the ringer. It's gone through the washing machine, been to the top of Yosemite Falls in January, been accidentally dropped half a dozen times, gone through four days of caving at Lava Beds National Monument, close to a dozen camping and backpacking trips, and even been thrown into the dog's water dish by my 3 y.o. daughter and it still fires up first time, every time. I don't have a single other light with a better track record.
I'll be buying more ZL's as soon as I can afford it; I have an SC600w, SC80c, and an H502w on my want list.
bbb74
Australia
I've got a SC51w, SC51, H51r, H51, and my brother now has a H51Fw which is really going to get bashed around. Apart from the first one they're fairly new. The SC51w is about a year old and used daily. The SC51 and H51r are getting daily use strapped onto my bike or helmet so they're getting pretty rough treatment including being directly sprayed with water and mud coming off the road.
No issues with any of them, but I haven't voted - will wait till much later in the year ;)
jk42
Had to return my first H600w - the switch worked for less than a day, after which it needed too much force to use. The replacement has been OK.
On my SC600w, the emitter is just a bit off center, but the beam is OK (and very floody).
(Both have the same acceptable tint, yellow with an ignoreable hint of what could be dubbed "xml sick green". Why, oh why, don't manufacturers just use T4 4A's.)
kaichu dento
現在の世界
I've only got one SC51w and have gifted an SC51 - both doing great, but not much abuse either. Since I'm planning on probably getting an SC600w I'll hold off voting until later too.
peterharvey73
I've had no trouble for the last 9 months with my SC600, so I just ordered a 38 gram H600 after waiting so long for a future HP12 XM-L, and toying with the Spark SD6 and ST6 which both seemed to be too heavy and underpowered...
bbb74
Australia
Well just had the first failure. The H51Fw is dead as a dodo. 5 months of daily use. The others are still going strong.
ponco
Hi all,
purchased H51 in 2010. Have used it randomly on hikings and other outdoor activities. No hard usage, never used in rain, no hard falls etc. In august this year torch went dead for no reason. Contacted ZL CS dept., paid repair fee and sent it back to China. Starting november contacted ZL again about status. Reply was they did not receive my package, torch was lost (last tracking point says it has reached China)! Thought i will spend some more cash to get quality light that will serve for some time. Now there is no light, no money but great disappointment. I have to say i was very happy with the torch until it worked, it perfectly fitted my needs, but confidence is lost now.
Pretbek
SE PA
"There is a high failure rate among people who vote in this poll."
Statistical use of these numbers is extremely limited, because the participants are self-selecting AND failures get counted 1:1 "per voter" and not 1:x "per total number of ZL lights owned".
To add to the numbers: I have owned an H502d for a staggering 35 days and it hasn't failed me yet. :p
EDIT: There, and because of my tiny phone screen and fat thumbs, I just voted that I DID have problems with my 502. Awesome.
eh4
I've had a couple failures with my light. Fixed them by cleaning the six contact surfaces.
Also in leu of dunking my light in water and then subjecting it to positive and negative pressure changes while submerged, I instead produced suction on the empty, open battery tube until the switch "pressed" in due to the partial vacuum inside of the light. I kept it in that state for a minute or two until I was satisfied that it wasn't losing vacuum. Did the same thing with the lens face except there was no volume to recreate a partial vacuum, no bubbles appeared and the switch certainly wasn't effected.
I find this H51Fc to be more reliable than many good tools.
If you experience a "failure", and then fix it by cleaning the conductive surfaces, is it a failure?
I'd vote no.
Dukester2
Received the H502d a couple days and hadn't worked since i got it. Trying to get an exchange from Zebralight which the process thus far has been painfully slow. I am hoping ZL makes it right!
eh4
That sucks, Dukester2, hope it's resolved to your satisfaction quick..
I'm really looking forward to getting an H502c, can't wait. Wish I had a big old pile of money to roll around in. ;-)
varuscelli
Texas
I've told this story before, but it might bear repeating. The first ZebraLight I ever bought (an H501w) gave me problems when it first arrived. I couldn't get it to work at all -- until I thoroughly cleaned and lubed the tailcap threads and tightened the cap down hard. Then it started working just fine. The first few times I loosened and tightened the tailcap, I had to tighten it pretty hard to get it to make proper contact. After a while, it eased into a state where normal tightening worked (and has been working that way ever since).
This might not have anything to do with the problem you're experiencing, Dukester2...but cleaning, lubing, and tightening the tailcap down relatively hard couldn't hurt (and might fix the problem).
eh4
ZL makes one single battery do an awful lot, and there are Six contact surfaces in the battery compartment that the current has to cross in order for the light to work.
Mine died a couple times. Cleaned the contacts and it came back like new.
Wiped the battery, the positive terminal inside the light, the negative terminal spring in the tail cap, the little gold ring down inside the tail cap, and the bare aluminum end of the battery tube that contacts the gold ring.
People swear by DeoxIT for cleaning electrical contacts, good luck.
Dukester2
Thanks for your experience and cleaning tip. With the headlamp in question I already sent back to ZL for exchange. If I do have problems in the future I will certainly apply your advice. Where do you get this contact cleaner, Radio Shack? There were also a couple times when I turned on the Headlamp whereas the body of the Headlamp would heat up but would not light.
eh4
Wow, that changes everything. Sounds like a critical failure.
