kwak
aha now i understand what you're saying. what 18650 are you using btw? perhaps it sags too much. try a sanyo 2600, flatter discharge curve. a cell that sags too much will prematurely stepdown on zebralights
that's selfbuilt's graph for the sc52 using 14500. it only steps down to MED when the cell is down to less 10%
I have around 20 18650 cells, from rubbish surefire through to non protected 3400mAh Panasonics.
This is not a battery problem it's a function of the torch.
To copy the description from the ZL site
Automatically stepping down from High to Medium, and from Medium to Low when battery capacity is low
So depending on the battery voltage the torch automatically steps down to 90Lm then 3Lm
I understood your point.
Are these real time measurements or it's just an example?
No sorry Nicola they were just figures i used as an example.
From the ZL site the torch will step down from high to medium (500Lm to 90Lm) then medium to low (90Lm to 3Lm).
If that was the case, I would see your point, but that's not the case. Not for me. I use Xtar 3100mah 18650 - basically, Panasonic 3100 18650 cells. I have never sat there and let my light stay at 500 lumen until it drains, I just wouldn't do that with this light, I would use a light with more metal in there for that, like a 2x 18650 light- but that's besides the point. I get just about the same amount on 500 lumens as I would if it didn't step down because I never run the batts that low. I would probably get closer to 1.7 hours or more.. either way. It wouldn't be 20 minutes that's for damn sure.
here's what they say on ZL-
So maybe you should get better batteries? That's if you are using crummy ones I guess.
If that works for you then good on ya.
For me personally i do NOT want a auto step down.
Those figures were just picked at random to better show what i mean.
I will time the step down when i get some free time and see what the actual time is.
The actual figure is irrelevant for me and my uses though as the cut-off voltages are 2.7v on both my non step down MKI and my step down MKII.
As i said above i have AW, Redilast, Panasonic non protected in capacities from 2200mAh through to 3400mAh the problem is NOT my batteries.
I just prefer a torch without a auto step down, simple.
