Anyone have ideas how to attach effective cooling mass to this light because I don't want to disassemble the body?
Maybe you should look at a different/larger flashlight instead?
Just received the SC600F III Plus and wow talking about harnessing the power of the sun I'm impressed but I think the times on high might be a little off I played with it just a few times on high and my battery was drained to 50% so I'll try a few other battery's and get back to you all
...I would love to see a chart showing what amperage it draws on the various H1 and H2 modes, though. Most of my cells can only handle 0.5-2.5A constant draw, so I've only been using those with H2 at the most. I have one 10A draw cell that I can confidently use on the higher H1 modes. It would be nice to know if some of the other PID modes are also safe! I don't have the equipment to test it myself, unfortunately...
That's great to know, thanks.Hi. I just tested the current draw at the tailcap using my Fluke 87V. Ballpark measurements were 3.5A on H1, which started to drop quite quickly as the PID kicked in. H2 variants were about 0.5A, 1.0A, and 2.0A, respectively.
I agree that this led is a wall of light if that is what your looking for. I played with the SC600Fd III Plus and a SC600w III Hi. The Plus seems to step down very quickly and eats batteries like crazy. I wonder what it would look like if it didn't have the frosted sense filter? I think is is a good show off light but for practically uses the XHP35 lights work best. Just my opinion of course.
Time to put a Sony VT6 in mine. Looks so good it makes me think the charts are wrong:
http://lygte-info.dk/review/batteries2012/Common18650comparator.php
That's not my experience at all. I've never seen it step down from H1 in normal operation [...]
It really does. I can notice mine starting to step down after about 45 seconds (in white wall conditions ).
XHP needs too much power to run in a small flashlight on one 4.2 volt battery. Bad choice by ZL. XP-L2 would have been better.Mine steps down big time at 1500lm. Within just a few minutes it is usually at a lower output than H2. And this is with the pid set for the highest temp. I am using the 18650ga's from ZL.
No it doesn't. It steps down because of the heat(thermal regulation)not the voltage or voltage sag. The XHP50 and 30 are fine choices with the right driver. With the right driver they can still hold turbo(1300-1500 lumens) down to almost 3.0 volts. The XP-L2 has less then half of the maximum light output of the XHP50 and would have never achieved the same performance/output. I am pretty sure ZL knows what they are doing.
There is ever so slight truth in at the boost converter to run an XHP50 is slightly more inefficient than the driver to run a 3ish forward voltage emitter. But in truth, the XHP50 will just be outputting more lumens anyways so it will need more power and run hotter. the XHP50 and XP-L2 are very close in generation so very close in efficiency.
Hope everyone else enjoys this torch as much as I do! Happy holidays, folks!
