Gunmetal
- Joined
- Aug 19, 2006
- Messages
- 9
0) What Region/Country/State will the light be purchased in?
_X__I will be mail-ordering or buying online, so this doesn't matter.
_X__I am in North America. More precisely I am in ___USA_________.
1) Price Range: An easy question, but you may change your mind after answering the rest!
_X__I could spend $40-60.
2) Format:
_X__I want a flashlight.
3) Length:
_X__2-4 inches. (Pocket carry)
_X__4-9 inches. (Holster carry)
4) Width:
_X__I prefer a long narrow light.
5) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
_X__I want common Alkaline batteries. (AA)
_X__I want lithium batteries. (CR123, AA)
6) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_X__I want to walk unpaved trails. (40 lumens)
_X__I want to do Caving or Search & Rescue operations. (60+ lumens)
_X__I want to light an entire campground or dazzle an intruder. (100+ lumens)
7) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an "X" on the line below.
Throw (distance)-----XXXXXX-----------|----------------------Flood/close-up
8) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries.
_X__60-240 min. (1-2 hours)
_X__240-360 min. (4-6 hours)
9) Durability: Generally the old phrase "you get what you pay for" is very accurate for flashlights.
_X__Very Important (Camping, Backpacking, Car Glove-box.)
_X__Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
8) Switch Type:
_X__I want a "clickie" switch. (Stays on until pressed again.)
_X__I want a momentary switch. (Only stays on while held down.)
9) Switch Location:
_X__I want a push switch on the back end of the body.
_X__I want a rotating end-cap switch.
10) Operational Modes: Check all that apply.
_X__A simple on-off is fine for me.
_X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
11) Is it important whether the body is metal or plastic/composite?
_X__I don't care.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
_X__Waterproof – how deep: _Dunkable___
_X__Pocket clip
_X__Wrist/Neck Lanyard
Looking for a light with a balance of runtime and moderately good throw with a decent spillbeam (not a pure spot). This light will serve as a general EDC and will be carried along with a "tactical" light (currently a G2, hopefully an A2 once I can afford it).
I am not concerned about the 2-stage feature, I could live with or without it... same goes for the twisty tailcap, but again, it would be strongly preferred. I do require a pocket clip for bezel-up back pocket carry.
I was looking at the Nuwai TM-301X-3, but I strongly prefer the "tactical twisty" style tailcap (momentary w/ twist) and I've read some reports of durability issues. The Fenix L2T also looked like a contender, but AFAIK there's no pocket clip for these.
I'd like to hear any suggestions. Thanks!
2) Format:
3) Length:
4) Width:
8) Switch Type:
9) Switch Location:
_X__I don't care.
_X__Pocket clip
