Re: Most Powerful Green Lazer for under $500
A weapons mounted high powered laser in the field can serve a number of extremely important tasks. In a fire fight with an enemy firestation at 700 to 1500 meters or more, an extremely powerful green laser can not only pin point the site for return fire from the rest of the squad (or mortars) with a quick blink of the beam, but it can also temp impair the bad guys with the light shock (prolonged exposure)..
I really do not care if they are blind or not - in fact, sicne they are shooting at me, they need to be removed from God's earth since I believe we are the good guys. At 300mW, however, the issue of 'blinding youself' comes into play. Need to have correct eye protection if this technique is employed. Using high powered IR lasers (if every one has NV that works - and many do not) a fireteam can engage with surprise about 90% of the time in most regions of conflict. Problem is that replacement parts and complete units are sometimes long in coming - been trying to find a unit for myself around here and other forums before I go back that I can afford. this is a tough thing for most soldiers. I am still looking.
The Green laser at $250 (low end 90 mw version) can help. But the big boys at 250 - 300mW's are a real life saver many,many times
If you are needing to ID a target for air support with no communications (and this happens more than you might think), a green laser can pin point a target with a blip, and air support can make a run knowing where the laser came from and the target the laser was hitting. Keeps 500 pound bombs off family and friend heads.
I understand the need for one, as I have a 90 - 100mW that I am trying to trade up with it. have heard that it makes you "stand out," and it does if you are not aware of your surroundings and the field conditions. Knowing what is happening around you in the "fog of war" can save your life with tools like the high powered laser.
Sometimes, the folks on the ground have to make due with what they have. I wish I could say that all soldiers are outfitted with everthing they need by our country, but it just is not so all of the time. I praise the supply folks - they are wonderful. However, NV, lasers, SP ammo, new(er) firearms, and many other items that keep us alive are not handed around like candy we give to the kids.
don't knock it until you have tried it!
Bill Herny
