I searched the forums, and found the following form to provide the appropriate information to get me started with this. Your help is greatly appreciated, I currently use a Dorcy 3 watt (3 AAA's), and want something much brighter.
Looking for a recommendation
Short Essay Question: What do you intend to use this light for?
For running in the darkness before or after work. Current light not bright enough to notice all sticks, cracks in the sidewalk, etc… Needs to shine and light usually up to 50 ft ahead and the farther the better to check for dogs, people, etc…
0) What Region/Country/State will the light be purchased in?
Dayton, Ohio
1) Price Range: An easy question, but you may change your mind after answering the rest!
Hoping for $50 - $60, but would consider higher if light so much brighter
2) Format:
LED Flashlight please
3) Length:
Small enough to carry on runs
4) Width:
long/narrow is preferred
5) What batteries do you want to use?
Only common AA and AAA sizes are acceptable, rechargeable primarily and alkaline if needed
6) How much light do you want?
The more the better, 2 or more brightnesses
7) Throw vs Flood:
Something focusable is highly desirable, but if that's not available then I would do put the X right in the middle:
Not really sure what would be best, advice appreciated!!
Throw (distance)----------------------X----------------------Flood/close-up
8) Runtime
More is better, but hopefully 3-5h at least.
9) Durability:
Durability is extremely important. May get slightly wet due to sweat or light rain.
8) Switch Type:
Clickie preferred
9) Switch Location:
All of these are acceptable:
I want a push or sliding switch on the body near the head.
I want a push switch on the back end of the body.
I want a rotating head switch.
I want a rotating end-cap switch.
10) Operational Modes: Check all that apply.
on/off is fine
multiple level is a requirement
11) Is it important whether the body is metal or plastic/composite?
Metal. For sure.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
Waterproof/resistant is required.
Corrosion resistant or hard-anodized finish is very desirable.
Any comments about what I should get here? Thank you to all the experts who take the time to respond to this.
Let me know if any questions!
Dayton, Ohio
2) Format:
3) Length:
4) Width:
7) Throw vs Flood:
8) Runtime
9) Durability:
8) Switch Type:
Clickie preferred
9) Switch Location:
on/off is fine
Metal. For sure.
