Who has used a P2DCE head on a L1DCE body?
Spordin
How did it work? How much brighter than the L1DCE head? How was runtime with just the 1xAA battery? Does it work OK with Alkies, lith's & rechargeables?
Steve L
SE Michigan
L1D,L2D,P2D are all exactly the same head. The L2D and P2D will be brighter than the L1D on turbo because of the higher voltage(3.0v vs 1.5v)
mchlwise
I've done it too, and it is EXACTLY the same.
If you compare the heads, you can not tell which head is which.
It's the same head.
If you're asking how much brighter the P2D is than the L1D, it's significant... but I don't think that was the question.
:candle:
Spordin
Thanks, didn't realize it was the exact same head. No particular reason to do it then.
UnknownVT
As all the replies indicate the head is the same between the P2Dce and L1Dce -
There is a direct side-by-side comparison between a P2Dce and L1Dce in -
Fenix P2Dce Comparison Review
P2Dce vs. Fenix L1D-CE (NiMH) both on Turbo (max brightness)
