scott011422
- Joined
- Feb 5, 2008
- Messages
- 104
Hey guys, Would someone be kind enough to help me find a resistor for the following specs? I keep getting different values with the online calculators. Thanks
Source voltage will be 12v running one led
LED voltage is 3.0 to 3.4
Specifications:
Size (mm) : 3mm
Lens Color : Water Clear
Reverse Current (uA) : <=30
Life Rating : 100,000 Hours
Viewing Angle : 20 ~ 25 Degree
Absolute Maximum Ratings (Ta=25°C)
Max Power Dissipation : 80mw
Max Continuous Forward Current : 30mA
Max Peak Forward Current : 75mA
Reverse Voltage : 5~6V
Lead Soldering Temperature : 240°C (<5Sec)
Operating Temperature Range : -25°C ~ +85°C
Preservative Temperature Range : -30°C ~ +100°C
Specifications:
Size (mm) : 3mm
