KL4 with Red 1W
McGizmo
Maui
Well I like the KL4 reflector so much that I have already done a few sacrilegious mods to these cool bezels. Today, I finished a red 1W that sports a DownBoy 400 PCB nested into where the original driver used to be. I realize that the KL4 is a pretty expensive host but when you want the best....
The red beam is so clean and bright that I think I should have resistored the DB400 down to under 300 mA. This bezel will work on 1 to 4 123 cells. On a single 123, it will likely drop out of regulation early but even in DD, the red is likely to remain bright until the lithium cell is depleted.
Here's a shot of the DB400 residing in a hole bored through the KL4's stock PCB. Boring through SMD components and G10 is a different experience. Not sure about leads and feeds. /ubbthreads/images/graemlins/grin.gif
For me, this reflector in the KL4 puts the NX05 out to pasture.
- Don
FalconFX
Davis, CA
/ubbthreads/images/graemlins/drool.gif
Paypal Sent!
yclo
Melbourne, Australia
My god... that poor little SF PCB was just sitting there, now it looks like that scene from Aliens where they pop out of someone's stomach!
But also, /ubbthreads/images/graemlins/bowdown.gif
tvodrd
*Flashaholic* ,
Hawthorne, NV
Don,
Expensive host amen! Pretty cool. I did my first DD red/orange today and am trying to decide if I like it. (Bright sucker!) Another current proj is to bore out the potted electronics and LS /ubbthreads/images/graemlins/icon15.gif and re-do with a R2H on a light for a friend. I will probably rot in Hades/Heck for that one.
Larry
paulr
Nice! I think red led Vf is around 2.2-2.4 V, so it should be able to use a 123 cell til there's nothing left.
Note that even at 400 mA, at that Vf you're still well below the rated 1 watt led power.
PaulW
Laurel, Maryland
Don,
I'm assuming that the KL4's stock PCB was already messed up in some way before you started boring into it. I don't want to face the pain of that assumption being false. /ubbthreads/images/graemlins/ooo.gif
Paul
Slick
Nor Cal
Very cool indeed! /ubbthreads/images/graemlins/smirk.gif
McGizmo
Maui
PaulW,
This KL4 had a terminal case of heart murmer so I had to put it down. It was enrolled in an organ/ body part donor program so I did the best that I could. Yeah...... right. /ubbthreads/images/graemlins/grin.gif
- Don
McGizmo
Maui
Bernhard,
The beam has a center spot that is about ideal in angle; about 20" in diameter at about 6'(little over .5 meter at 2 meter I would guess). For the beam shot, below the light is about 14 inches from target:
There are no artifacts and spot and flood are very even and useful; perhaps a bit too bright.
- Don
IsaacHayes
Missouri
Wow, a far throw high power red. If only we could get a hold of these reflectors.....
McGizmo
Maui
[ QUOTE ]
IsaacHayes said:
.............. If only we could get a hold of these reflectors.....
[/ QUOTE ]
You can, you buy a L4. /ubbthreads/images/graemlins/smile.gif I would have to guess that SureFire knows what they have here; the perfect photon management devise for a pocketable 1W Luxeon........
I also have a modified half pint L4; R2H HD 1W, BB500 on E1 body. This is a very nice light!
- Don
