lovemylexicon
- Joined
- Mar 26, 2011
- Messages
- 72
Eagletac P20C2 MK II with XM-L HO module with 2 new Panasonic CR123 batteries installed on the same day, and both tested at 100% capacity with the ZTS tester---after using the light at MAX and General and Lo output for seven to ten days for a short duration each time and testing the batteries today with the ZTS tester, one battery consistently showed a remaining capacity of 20%, and the other battery consistently showed a remaining capacity of 100%. I tested the batteries over and over for many rounds, and each time the result was the same.
My question: Which is the culprit---the light, the batteries, or the battery tester?
