digitaldias
- Joined
- Feb 3, 2013
- Messages
- 1
This is a weird one:
When I power my battery charger (MAHA MH-C800S) it runs through the power on self-test, then proceeds to blink/flash "done" repeatedly on all the 8 battery stats indicators.
Coming from the PC world, I've tried to start the charger holding down the condition button, this shows me a full LCD display of the "amound full" things inside the battery graphic. Starting the charger holding down the "SOFT" button does not appear to do anything.
I seriously believe that it is a matter of figuring out how to reset the box, but I have not figured out how. Reading about this charger and the 808, which seem to be identical in operation, I was hoping that someone knew a secret combination that I could try - i.e. Since some of the operation of the device revolves around inserting a battery in slot 1, I figured, maybe, there's something similar one has to do to reset the device. Oh, I've tried restart the device with a battery in slot 1 holding both the condition button, the "soft" button and both during power-on, but nothing have helped so far.
I can certainly produce "odd" behavior, such as starting it with a battery in the leftmost slot, then inserting another battery in slot 2 gives me a "Charging" indicator for slot 3(!)
I've used Sanyo Eneloop exclusively for this device, and the last thing that I charged before I noticed this behavior was two AAA batteries. I've never done anything else than just insert batteries and wait for them to indicated "done". Also, I tend to leave the batteries in the charger for a long time before I check back on them - the charger is always powered.
I would hope to have this fixed without having to send anything in. As I mentioned, I hope there is a secret "reset to factory defaults" combination that I can try.
Looking forward to your answers,
From Norway,
Pedro
From Norway,
Pedro
